Old 01-11-2016, 03:59 PM   #1 (permalink)
...beats walking...
HEM paper (2014) on 2010 Prius Fuel Economy data
Stumbled across this recent "PEMS CONFERENCE 2014 - Fuel Economy Data" slide presentation by Rick Walters, P.E., HEM Data Corp:
http://www.cert.ucr.edu/events/pems2...a/24walter.pdf
It discusses how MPG values are derived under SAE J1939, and how/why different results often occur when different input parameters are used, ie: MAF vs. MAP, etc.; and, it highlights *why* the Prius MID fuel economy numbers tend to be 5% optimistic (see pages 16-18).
Apparently Toyota calculates MPG using exhaust gas Lambda (a ratio that defines the deviation from stoichiometric (14.7:1 A/F)), vehicle speed VS (KPH), and manifold air flow MAF (g/s):
MPG ≈ Lambda × 7.107 × VS / MAF
Thus, basically, Lambda, VS, MAF, and constant 7.107 determine MPG fuel economy.
Old 01-11-2016, 08:53 PM   #2 (permalink)
90 day: 35.79 mpg (US)
Interesting, but why is it consistently 5% high?
Old 01-11-2016, 09:56 PM   #3 (permalink)
Because they lie. If any error was perfectly random, same number high as low then I would believe it is out of their control. I once told a MacDonalds employee she had given me too much change. You could have heard a pin drop in that place.
I got so tired of being overcharged 98 cents at Wendy's I keep a receipt in my wallet, so they can not charge me any more than $4.61 until they raise the price again and even then they have got it wrong just about every way you can imagine, even as high as over $8.
regards
mech
Old 01-12-2016, 03:04 PM   #4 (permalink)
...beats walking...
...actually, it is because although the ECM "tries" to keep the engine AFR = 14.7:1 for optimum catalytic convertor operation, there are times (warm-up, heavy load, WOT, etc.) that AFR goes richer, and this royally "screws-up" the J1939 presumption that AFR is always 14.7:1, which the Lambda number should correct, but there has never been a calibrated Lambda sensor that I know of.
