Old 02-08-2011, 11:24 AM   #1 (permalink)
HHO or Brown's gas
I have built a pretty good electrolyzer and can create the gas. I also now understand it a lot better due to recent documents obtained thru a friend.
Understanding why and how it works has led me to a possible solution to running a vehicle on just HHO not as an additive.
First and foremost, browns gas or (atomic hydrogen /oxygen) causes an implosion not an explosion. How can an implosion improve the burning of fuel as an additive? Right, it can't...HHO myth number one exposed
secondly the ice has to be redesigned to run on HHO or brown's gas....
The modification shouldn't be all that difficult but I need help with this.
Implosion in cylinder at BDC (firing) should pull cylinder up. It would become a 2 stroke engine as no compression stroke is needed and power stroke is combined with exhaust stroke...
Intake of HHO as piston is going from tdc to bdc, firing at bdc and exhausting small amount of steam or water just before tdc.
Could a duel OHcam be modified to do this? gears reduced in size to open and close intake and exhaust ports twice each cycle???
Please help with this...I am not a mechanic although I have some Knowledge, and I am not a machinist...or electronics specialist...Probably all of the above to put this together. I have Stan Meyers' original documents...copies of course...
Old 02-08-2011, 12:51 PM   #2 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
Chemically, the reaction results in a reduction in volume compared to the starting situation - 2 gases forming a liquid.
If you forget about the heat, and there's lots of heat.
Physically however, the gas being formed (water) is heated so much that the volume is greatly and violently expanded.
Hence, it's an explosion in the real world.
No-one will claim that Challenger imploded .
This is rediculous.
It won't - see above.
You can't get rid of the heat quickly enough to get the implosion you claim.
Lifetime fuel consumption :
Old 02-08-2011, 02:14 PM   #3 (permalink)
My experiments prove otherwise. an implosion does occur. I created a combustion chamber out of 2 inch pipe, attached a balloon and there was an implosion sucking the balloon into the tube...As far as heat is concerned there is very little evidence of heat in any of my experiments. Do you know the difference in HHO (hydroxy gas) and brown's gas (atomic HHO) I am sure you do not by your comment...The challenger uses HHO (hydroxy) and yes it did explode. A brown's gas torch works on different principal. It uses atomic hydrogen/oxygen. This is why these torches operate at about 270 degreesF
yet will melt tungsten at 6000F. Atomic reaction of hydrogen atoms with the material you are welding. Do some research before you criticize my work.....
I am fine tuning my electrolizer hopefully to work with just water...
This is why I asked if there was someone skilled in electronics interested in my project.
Old 02-08-2011, 03:00 PM   #4 (permalink)
03Malibu - '03 Malibu
90 day: 29.34 mpg (US)
98 Stratus - '98 Stratus
90 day: 34.77 mpg (US)
Pen's Impala - '010 Impala LT
90 day: 26.27 mpg (US)
Next car - '91 Unknown
If it creates and implosion when at BDC, the most I think it can create is absolute vacuum of 0 psi, atmosphereric pressure will push on the bottom of the piston with a pressure of 14 psi to push the piston back up(down in the Newcomen engine). Not much pressure differential to do much work.
Newcomen steam engine - Wikipedia, the free encyclopedia
But I know nothing about brown gases or most everything else your talking about.
Old 02-08-2011, 03:36 PM   #5 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...what, another HHO hoax?
Old 02-08-2011, 03:58 PM   #6 (permalink)
I are aerodynamic kitteh!
t vago's Avatar
2000 Fiat Dakota Quad Cab - '00 Dakota Quad Cab SLT
90 day: 18.33 mpg (US)
Dakota A-B-A HAI - '00 Dakota Quad Cab SLT
90 day: 19.38 mpg (US)
Are we going to implement that faux science category yet?
2000 Dodge Dakota Quad Cab
2002 Chrysler Sebring Convertible GTC with transplanted 3.5L LH engine
Old 02-08-2011, 06:03 PM   #7 (permalink)
UFO
UFO's Avatar
Beetle - '01 Beetle GLS
90 day: 42.61 mpg (US)
4x4 - '89 Pickup DLX
90 day: 30.36 mpg (US)
Omg
Old 02-08-2011, 06:29 PM   #8 (permalink)
Ethanol Fan
Mr. Fox - '91 Mustang GT
90 day: 15.99 mpg (US)
Water and Hydrogen injection into the intake manifold has been shown to improve FE which is essentially all that the electrolyzers accomplish. The only scam about HHO is the people selling them for more than the $5-$20 in parts and claiming they improve your FE by more than 10%.
If you need a 2 stroke ICE to run off of water you would be better off starting with something that is already on a 2 stroke cycle.
And welcome to Ecomodder!
~Allch Chcar
Old 02-08-2011, 06:53 PM   #9 (permalink)
IamIan's Avatar
Arrow
What performance specifications have you achieved?
What kg of water input electrolyzed per hour?
What electrical input per hour?
If your source of electricity comes from RE it will be cleaner than Gasoline.
A BEV will travel further on the same amount of input electricity... ICE efficiency it very low.
Can't have it both ways ... if the chemical reaction produces heat in the torch ... the same chemical reaction will produce heat in an ICE.
Correction to your post:
'brown's gas' torches can produce flame temperatures up to 2,800 Degrees C ( 5,072 F ) when premixed in a 2:1 ratio with pure oxygen... 270 is on the extremely low end.
Old 02-08-2011, 09:44 PM   #10 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
Actually some of his comments are somewhat truthfull,
Hydrogen does implode briefly before exploding, given the time your engine piston is moving up and down this does actually affect timing greatly, the Hydrogen sucks up a little then blows it back down. This is known by people that have worked with hydrogen cars (not HHO) I have no doubt that if you could run an HHO only car it would be the same behavior.
Also Hydrogen has an unusual behavior in regards to heat, although it produces a very high temperature locally, that temperature is not transmitted very far, holding your hand a relatively small distance away from the torch is warm but doesn't burn you like a normal torch would at the same distance.
I have personally watched someone "weld" glass together with a hydrogen torch, it melts when in direct contact with the torch and doesn't pool like you normally would get, somewhat interesting for real welding also.
So he is half right on some of his comments. I wouldn't mind having an HHO torch myself, no fantasy that it would burn and melt stuff.
Cheers
Ryan
