09-01-2017, 07:25 AM
#51 (permalink)
Originally Posted by Grant-53
Running diesel engines on natural gas is getting serious attention for the bus fleets in north central Pennsylvania as natural gas is cheap there. GE put out bids for injectors to convert their locomotive engines to natural gas. Hydrogen is a highly volatile fuel and so is prone to pre-ignition; not something useful in a turbo diesel.
Propane injection works a treat with diesels. In blended use, due to how cheap propane is, you can save a whole lot.
Originally Posted by smallscaleH2
Not into the exhaust, over the exhaust. The idea is that the exhaust gas would wash out due to the water, in plain air. This is important as in plain air, there's no waste heat from the tailpipe itself, so it's easier to wash it out.
You're going to spray past the tail-pipe? That means the least improvement per gallon of water used.
I'll try a gravity-fed system first, seems simpler if I can get it to work.
Simple, un-metered, and erratic.
Well, no. There's the heat issue mentioned above. Also, if I do it at the exhaust, the sprayer doesn't need to resist the heat either, so many of the parts can be plain plastic then.
Heat, true. Which is why the original suggestion was for intake injection. Injecting a water mist right after the air intake or before the turbo is best.
Agreed. But this method is just a quick fix for Diesels and intented to improve air quality with these since I can't run fully on hydrogen in Diesels (hydrogen injection will work, but that's still more polluting than running on pure hydrogen). So the idea is that I get the hydrogen injection implemented first, and then make sure that much less (preferably none) of the generated air pollution gets into people's lungs.
First, do what's proven to work.
Understand how and why it works.
Nobody injects water into the exhaust. There's a good reason for that. A lot of racers and diesel tuners use it. There's also a good reason for that.
Also, a water injection system is already half of what you need to transition to a hydrogen system, if you still choose to go there.
And it works. It really works. I've had two or three installed. Race teams use them. Manufacturers have experimented with them, but don't use them because they don't trust consumers to refill the water properly.
09-01-2017, 07:43 PM
#52 (permalink)
Hydrogen is a waste of time on a diesel.
09-01-2017, 07:53 PM
#53 (permalink)
Sounds like yhe crowds gathered around Edison before the accdent and advent of non gas powered light.
1st gen cummins 91.5 dodge d250 ,HX35W/12/6 QSV
ehxsost manafulld wrap, Aero Tonto
best tank: distance 649gps mi 24.04 mpg 27.011usg
Best mpg : 31.32mpg 100mi 3.193 USG 5/2/20
Former
'83 GMC S-15 Jimmy 2door 2wd O/D auto 3.73R&P
'79 Chevy K20 4X4 350ci 400hp msd custom th400 /np205. 7.5-new 14mpg modded befor modding was a thing
87' Hyundai Excel
83 ranger w/87 2.9 L FI2wd auto 18mpg on the floor
04 Mitsubishi Gallant 2.4L auto 26mpg
06 Subaru Forrester XT(WRX PACKAGE) MT AWD Turbocharged 18 plying dirty best of 26mpg@70mph
95Chevy Blazer 4x4 auto 14-18mpg
04 Chevy Blazer 4x4 auto 16-22mpg
09-02-2017, 03:25 AM
#54 (permalink)
Those who sought to replace one combustible by another instead of going electric.
09-02-2017, 05:28 AM
#55 (permalink)
Too bad most electrical power comes from burning something.
That is correct, just substitute burning one thing for something else, some where else.
09-02-2017, 05:36 AM
#56 (permalink)
If I had an EV I'd get solar panels for my roof.
In my situation, with a non-ideal roof, having an EV would make having home PV panels cost effective.
My next car will be an EV or a plugin hybrid.
Combined with the home PV panels it will save instead of cost energy.
