Old 06-01-2008, 09:52 PM   #1 (permalink)
Beefy
Hi, Civic Ex owner just found this board...
Hello...new here. My daily vehicle is a 98 Civic EX coupe with nearly 200k miles. I average around 35mpg mixed driving, and 37 all interstate with cruise set around 70-73mph.
I am going to start using the methods you guys recommend and hopefully I can knock down some new numbers. I plan on doing some aero mods too. Probably a grill block off, remove mirrors/antenna, and lower the car. Some minor weight reduction will be employed as well.
Any other ideas?
Old 06-01-2008, 09:59 PM   #2 (permalink)
Awesomeness personified
AndrewJ's Avatar
Harold - '94 Civic CX
90 day: 54.51 mpg (US)
Margot - '08 Big Dummy
Send a message via AIM to AndrewJ
Welcome to ecomodder!
I think that hondaworkshop had good results with his Hot air intake on his 6th generation civic. I had good results with mine, but it's a 5th gen, so not *directly* applicable to your situation.
Oooh, before I forget (or someone else jumps in) get a scangauge or some other feedback device, it'll pay for itself VERY quickly.
If you're strapped for cash or just enjoy a good DIY project you might checkout the Opengauge/MPGuino.
"I got 350 heads on a 305 engine. I get 10 miles to the gallon. I ain't got no good intentions." - The Drive By Truckers.
Old 06-01-2008, 10:12 PM   #3 (permalink)
Beefy
Hi Andrew, thank you for the reply. The car has an aftermarket air intake, but I should probably clean the filter. When I bought it it had the intake, a header, and an aftermarket muffler. I swapped the muffler for an OEM one b/c the aftermarket one was too loud. I also did a tuneup on it about 1000miles ago...new plugs, wires, and a distributer (old one was dead).
I'm wondering if I extend the intake piping down away from the motor if it will help any with receiving cooler air.
I would like to get a scanguage. Can you tell me more about how it will help me? Is it just by seeing your mpg live that it helps you keep your foot off the gas?
Old 06-01-2008, 10:23 PM   #4 (permalink)
AndrewJ's Avatar
Cooler air is generally great for helping to get a little more power. The usefulness of cold air intakes for better gas mileage is debatable.
Essentially a cold air intake gets denser air (more oxygen = more fuel = more power)
A hot air intake does the opposite (less oxygen = less fuel = less power)
With hot air, you have to open the throttle more to get the same amount of power, so you reduce pumping losses in the engine and make it more efficient. (that's the theory anyway) Only way to tell for sure is to try it
Old 06-01-2008, 10:24 PM   #5 (permalink)
Weight Reduction
ankit's Avatar
4x4 - '06 Altima 2.5 Special Edition
90 day: 29.04 mpg (US)
Mom's Van - '99 Voyager SE
90 day: 25.62 mpg (US)
Send a message via AIM to ankit
I have learned by reading on this website that warmer air is your friend since the engine runs most effectively when warm. But I don't know if this is true in summer also.
EDIT: I guess Andrew was working on his post the same time as I was, his is way more informative though.
Most of my trips are made in rush hour traffic to and from school.
Live Simply So Others Can Simply Live
-Ed Begley Jr.
Old 06-01-2008, 10:53 PM   #6 (permalink)
Beefy
Ahhh ok. I was thinking the colder air would allow the motor to use the fuel I was giving it more efficiently but what you're saying is that it will simply use less fuel (computer retard timing possibly?)
What kind of mileage can I reasonably expect to see with a few mods and some conscience driving habits?
Has anyone calculated how big of a difference it makes to lower the vehicle?
Old 06-01-2008, 11:10 PM   #7 (permalink)
AndrewJ's Avatar
I think you can reasonably expect to hit 50mpg with no mods and just driving habit changes (that's assuming you have a manual transmission)
If you have an auto, that changes things a bit. Prolly 45ish.
With mods, the sky is the limit.
As for lowering, it's gonna definitely help.
There was a thread in the aerodynamics forum that refrenced solid numbers for lowering gains, something about an aeromodded Ford Fusion bonneville car.
Old 06-01-2008, 11:16 PM   #8 (permalink)
AndrewJ's Avatar
aah yes, here it is.
Lowering takes off 0.08 Cd (at least on that car)
Old 06-01-2008, 11:34 PM   #9 (permalink)
Beefy
Wow! I had no idea it could make that big a difference. I am buying some coilovers from a friend so hopefully I can test different heights and see which nets the best numbers.
Old 06-03-2008, 12:42 PM   #10 (permalink)
The Honda - '98 Civic DX
90 day: 37.12 mpg (US)
Send a message via AIM to spitfire9703
Hey Zach, I joined the boards not too long ago and own a 98 Honda Civic DX and since I read just a few tricks on here i went from getting 42mpg on the interstate to 49mpg. So you could easily bump yours up without much modding. Welcome to the boards!
--Best Tank 49.07mpg--
Civic HX owner, seeking 60 MPG WTFM8 Introductions 14 03-10-2012 01:05 PM
Why I'm Choosing a Civic Over a Metro Wayneburg General Efficiency Discussion 43 03-02-2011 05:11 PM
Civic VX VIN Info TomO Off-Topic Tech 5 12-07-2010 02:52 PM
Any guesses on '83 Civic mpg? Ryland General Efficiency Discussion 7 07-12-2008 09:40 PM
found a civic TheDon Off-Topic Tech 13 06-14-2008 02:56 AM
