Old 11-14-2012, 06:17 PM   #1 (permalink)
1994 civic vtec -e would turbo kit get more mpg
i have 94 civic hatch vtec-e 5 speed would turbo kit do better mpg ???
Old 11-14-2012, 06:45 PM   #2 (permalink)
Not likely.
Old 11-14-2012, 06:57 PM   #3 (permalink)
No.
Old 11-14-2012, 07:35 PM   #4 (permalink)
Sven7's Avatar
Boo Radley - '65 Ford F100
90 day: 13.28 mpg (US)
You want lower density air in your engine so the fuel has less to mix with. Cramming air in at higher pressures will only let it mix in more fuel... and you know what that means.
Old 11-14-2012, 08:30 PM   #5 (permalink)
Rusty crusty trusty - '94 Honda Civic Cx
90 day: 36.13 mpg (US)
Vx - '92 Honda Civic Vx
90 day: 49.97 mpg (US)
http://ecomodder.com/forum/showthrea...rbo-11881.html
Short answer probably yes if tuned properly.
Old 11-14-2012, 09:51 PM   #6 (permalink)
2000neon's Avatar
VX - '94 Honda Civic VX
90 day: 47.95 mpg (US)
Sure a turbo one can get 55 mpg, however a normal D15z1 (vx vtec-e) will do better than that right from the factory. Why modify and put time/ money into something to maybe get the same mileage you already had.
Old 11-14-2012, 10:01 PM   #7 (permalink)
90 day: 40.51 mpg (US)
I'd trade you my B18 Del Sol for your hatch.
Leave it stock man, it's an awesome car.
Old 11-14-2012, 10:01 PM   #8 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
If you drive in an ecomodder fashion you might get the 'same' mpg because you would never engage the boost.
The idea behind a turbo is to allow an engine that would underperfom in hp to provide more hp only when needed.
THe new Eco-drive hybrid from Ford, the fusion, has the ecoboost turbo BUT also has an electric motor. that is where the increased mpg is coming from
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 11-14-2012, 10:10 PM   #9 (permalink)
I think the mpg increase are from it being a downsized Atkinson-cycle engine (2.5L -> 1.6L), the turbo and electric motors are probably mostly to make it more enjoyable to drive.
Old 11-15-2012, 12:46 PM   #10 (permalink)
Burn lean and prosper\\//
VLX - '93 Honda Civic VLX
90 day: 51.1 mpg (US)
The 3 stage vtec car has a p28 I believe which made it easy to tune. No way to tune a p07
turbo vtec-e hatchback
