Old 08-03-2008, 02:58 PM   #1 (permalink)
Fizz - '06 Fabia Combi
90 day: 56.62 mpg (US)
Hi from the UK
Just registered - this is the forum I've been looking for for some time!
I have a Citroen Xantia HDi, for the non-Europeans that's a hatchback with already very good aerodynamics, a class-leading (8 years ago) direct injection turbo-diesel with 110hp. I get up to 55mpg (UK) or 5.1 l/100km, measuring over 600 miles, but with fuel at over $2.50 a litre I would like to do better...
It looks to me like adding an undertray at the front and back will be worth doing - the car may well have had one at the front from the factory.
If anyone has fitted a mpg display to this car, I'd be very interested to hear how. It has a OBDII connector which apparently uses an ISO standard.
Simon
Old 08-03-2008, 07:23 PM   #2 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Scangauge II would be the ideal choice for an OBD II car.
Old 08-03-2008, 10:11 PM   #3 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Hi Simon - welcome to the forum.
The ScanGauge is an excellent tool, or you could build your own MPGuino, if you're the DIY sort.
Is this your car?
Seems like they could have made the aerodynamics even better if they'd not gone for the "faux notchback" look!
I was just having a conversation about Citroens with my neighbour a couple of hours ago. (He's been stopping by regularly to chat, watching the progress on my Kammback construction.) There was one in town today for a bit car show - probably a 70's DS - and he commented on its apparently good aerodynamics.
Darin
Old 08-03-2008, 10:24 PM   #4 (permalink)
$54 worth it? Probably not. But that's what coroplast election signs are for.
Old 08-03-2008, 10:40 PM   #5 (permalink)
Hi-Tech Redneck
Originally Posted by BlackDeuceCoupe View Post
Bwahahaha!
But... I would have to wait until after the elections, right?
Depends on whether you like the candidate or not
Old 08-04-2008, 06:33 AM   #6 (permalink)
Yes, that's the car - or at least the Mk1 version. Mine has a slightly different grille, A/C, more airbags - and more weight. They all feature hydropneumatic suspension - amazingly effective but it does mean engine-off coasting is not possible. Don't really want to lose suspension, brakes and steering...
What would be better than the faux notchback? Simply filling in the triangle between the top of the roof and the boot lip?
Just discovered the MPGuino - looks good. I know some have had no luck using ELM devices. At least I get something to play with if it won't work with my car...
Simon
Is this your car?
Darin
Old 08-04-2008, 10:05 AM   #7 (permalink)
Something like that, yes. There's an ideal rear angle/shape which simply drawing a line between those two points might not satisfy exactly, but a properly tapered roof/hatch transition at the rear would lead to a smaller trailing wake and would be better than the current shape. Air flow separates at the trailing edge of the roof in this notchback design with no chance of reattachment on the short "faux" deck lid.
I just bought a crx :) chipX Aerodynamics 23 02-14-2009 08:21 PM
Hi From The UK markgreenway Introductions 6 07-23-2008 09:59 PM
Diesel in UK now $10 a gallon AXMonster EcoModding Central 2 06-17-2008 12:13 PM
