Old 11-05-2009, 01:33 PM   #31 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Originally Posted by tjts1 View Post
Nothing you say makes any sense at all. But I'm sure that won't stop. Keep it up.
Odd, I understood it perfectly. Must be a redneck thing...
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
Old 11-05-2009, 01:50 PM   #32 (permalink)
Moderator
tasdrouille's Avatar
The Guzzler - '08 Elantra GL
90 day: 33.12 mpg (US)
Got Soul? - '011 Soul 2U
Originally Posted by Christ View Post
Speek fer yerself, buddie!
I like the idea of brighter lights, mostly because I live/drive in rural areas. It's nice to see the deer with enough time to stop.
You just need wider beams for that, not more light. It takes very little light to notice the reflection in an animal's eyes, especially when the background is pitch black. Actually, even with more light, what would be most noticeable is still the eyes, because animals usually blend in with their environment.
www.HyperKilometreur.com - Quand chaque goutte compte...
Old 11-05-2009, 03:35 PM   #33 (permalink)
At 55-60 MPH on local roads, I want to see further as well.
In some cases, though, I think people confuse headlight bulb quality with headlight lamp crappiness. If the lamp is cloudy, the bulb won't make a difference. I see people with crappy lenses going and getting these $20 a bulb headlights, and expecting a major change with them... Yup - Keep spending it, buddy!
Old 11-05-2009, 04:05 PM   #34 (permalink)
My Hella H9 halogen projectors.
If you can't see with these, you shouldn't be driving.
9005 halogen bulb in 20 year old 9006 factory bmw projector.
Nobody needs HIDs.
Natural sunlight.
Incandescent lamp. Very similar spectrum output to regular halogen bulb.
HID light
http://ledmuseum.home.att.net/spectra.htm
HID bulbs fool the brain into thinking that the light is brighter when in fact the narrow spectrum reduces your ability to see contrast. The worst part about HID bulbs is the glare from a wet road surface to oncoming drivers. I would have no problem if HID headlights were banned in this country.
Old 11-06-2009, 02:18 PM   #35 (permalink)
for(cD i=.25;i>.16;i--)
UltraHatchy - '00 Insight 5spd
These graphs are probably deceptive because of their normalization: the peak output of the light seems to be rescaled so that it ends up at ~4000 "intensity counts". If we consider that for a given power, an HID bulb will produce a whole lot more lumens, and in the specific situation that we're talking about, the claims are something like 2.5x the output of halogen bulbs using less power, the graph starts to smell funny.
Here's a quote from wikipedia that might shed some light (sorry) on the issue at hand:
"[...] luminous flux is adjusted to reflect the varying sensitivity of the human eye to different wavelengths of light."
and then
"The lumen can be thought of casually as a measure of the total "amount" of visible light in some defined beam or angle, or emitted from some source. The number of candelas or lumens from a source also depends on its spectrum, via the nominal response of the human eye as represented in the luminosity function."
both from http://en.wikipedia.org/wiki/Lumen_(unit)
so if we made generated graphs of the different headlight options in question and did not normalize for output, they would look look very different.
Old 11-06-2009, 05:59 PM   #36 (permalink)
Deceptive - '98 Neon R/T
90 day: 44.38 mpg (US)
christ, i try not to drive when i dont have to, but unfortunately my job is driving trash trucks. Itd be nice if the city would let us start later on foggy days, but thats just not gonna happen. Even worse is when they switched to cng, they bought cheap junk trucks. There rediculously, dangerously slow, pulling out scares the crap out of me.
Every 2 years theres usually a big pileup on the freeways, 50 cars or more.
Old 11-07-2009, 03:40 PM   #37 (permalink)
Ecomod noob
zjrog's Avatar
ZJ - '95 Grand Cherokee Laredo Upcountry
90 day: 20.57 mpg (US)
Neon - '03 Neon SE
90 day: 36.28 mpg (US)
S'Crew - '02 F150 Supercrew XLT
90 day: 16.4 mpg (US)
EX - '94 Explorer
90 day: 19.58 mpg (US)
Ranger - '90 Ranger
Last 3: 28.02 mpg (US)
I agree that more light in rural areas is a boon. As well as a wider beam. I replaced my stock Neon headlamps with some aftermarket units that have separate H7 bulbs for the projector low beam and reflector high. While a VAST improvement in both low and high, I still would like more. The projectors give a very defined cutoff that takes some getting used to. The bulbs that came with the headlamps are really crappy and give the highbeams a sort of "flashlighty" appearance. I swapped to some Osram H7s and that improved. And were still just 55W.
I still want more light, I drive in the desert...
When it comes to Heroes, RENEGADES are mine!
Old 11-08-2009, 01:06 AM   #38 (permalink)
wdb
lurker's apprentice
Scootie - '08 Fit Sport
90 day: 37.19 mpg (US)
Would you please drive ahead of me on my nightly commute and make sure all the deer are looking my way? ;-)
H9's are very nice bulbs.
Having driven a very considerable number of miles in rural countrysides behind both kinds of light (HID and halogen), I agree. Halogen lit landscapes have more contrast and color.
Speaking of upgraded bulbs: anyone with 9005/HB3 or 9006/HB4 bulbs should look into. HIR 9011/9012 bulbs. They produce a tremendous amount of light at the same wattage as stockers, do not add glare to oncoming drivers, and can be popped right into stock lights with only a slight modification to the base. They're expensive but worth every penny IMO. And they really last, unlike a lot of aftermarket bulbs; I have been running the same 9011's for almost 100K miles in two of my cars.
The fine folks at rallylights.com sell 9011's: Susquehanna MotorSports - Auto Performance Product
Old 12-20-2010, 02:42 AM   #39 (permalink)
morderburg's Avatar
Send a message via MSN to morderburg Send a message via Skype™ to morderburg
Originally Posted by zjrog View Post
I know folks that have had good results with HID kits from vvme.com HID kit Xenon HID Conversion Lights LCD Projector Tattoo kit CCTV for sale[/url]. While I am pleased with the aftermarket housings and the H7 halogens, I want better low beam output, and HATE seeing the glare from incorrectly fitted HIDs. I really don't want to be "one of them"... Its either that or get a rally pod for lighting on the Neon. And I KNOW that will kill my FE...
is that VVME HIDs decent and good quality??? i searched on google and this forum, some good reviews with good experience while some bad reviews....
will that plug-and-play sets be enough or need extra relay in case of flickering....
any guys once ordered from vvme.com can give me suggestions....i will appreciate it....
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 979 12-26-2011 10:37 AM
AC Dodge Neon Electric Conversion Videos bennelson Fossil Fuel Free 59 10-25-2011 08:30 AM
FS Silver TDI Corrado with Black Leather 100% Diesel Conversion with Origninal Paint G60ING For Sale 8 03-09-2009 01:34 AM
Propane or natural-gas conversion kits! blackjackel Fossil Fuel Free 18 10-03-2008 10:01 AM
E-Bike Conversion Kits in Canada caledondave Introductions 3 07-30-2008 11:11 PM
