Let's take a look at each of your comments individually for the sake of clarity.
Originally Posted by mcrews
your reply reflects just about everything I said.
Instead of acknowledging THE FACT that you admitted to, you want to throw up defections.straw man arguements.
"if only you knew me" wow....get a grip. We do know you, read your first post.
How have I misrepresented your position on the subject (which is what a strawman is)?
I don't have to acknowledge what I said, because it's all there plain as day, but I will summarize (acknowledge) what I wrote:
1. The retrofit is illegal
2. The retrofit is annoying to other drivers
3. The light is not properly distributed (not optimized in your words)
4. The retrofit resulted in dramatically more usable light and safety
Please, tell me what I need to admit. I've agreed with most everything you have stated or implied.
listen to yourself " I have posted nothing that would support this claim." You posted your comments!!!
Light coming uot of an iccorrect housing is NOT improved light.
Car Analogy:
(more) power coming out of an incorrect transmission is NOT improved power.
Of course, the term "improvement" is subjective, but in general receiving more of a desired output is what we are aiming for.
And like most ricers, you are COMPLETELY unaware of the impact of improper nighttime lighting on the eye.
I don't know any "ricers", so I can't comment on their level of awareness. I did, however, mention in my last post that I considered the impact of lighting on the eye of others. Not only did I consider the impact, but I tested it from their perspective so that I could make an informed decision about what I am doing. This is evidence of an individual who is concerned with others.
9 yrs. YOu have been doing this 9 years. Do you realize how really stupid and "i have my head in the sand' you sound?
Maybe, I would forgive you if this was 3-4 yrs ago.
But the amount of FACTUAL information available that proves you are uniformed is staggering.
Fortunately for me, I do not require forgiveness of anyone, but what am I uninformed of? I am pleading to be enlightened, but instead I am receiving mostly ad hominems.
"I aim it low" So you admit that it causes others problems and you admit that you 'sacrifice' because of it.
As in all things of life, sacrifice for the sake of bringing about balance is a necessity.
My questions for you:
1. Assuming there are legal and "optimized" retrofit kits available for my application, what is the maximum amount I should be expected to pay for the sake of compliance of law and other driver comfort?
**********again, self-centered punk*********
Driving is a priviledge.
2. Should all things that could negatively impact others environment always be avoided?
3. Is it ever appropriate to break the law? Are there some laws that are acceptable to break under certain circumstances?
amazing, really.
I see more ad hominems and a regurgitation of a line from the DMV Handbook, but no answer to my questions. This makes my understanding of where you are coming from impossible.
you are an admitted liar. To law enforcement no less.
Is there any better kind of liar than the admitted kind? It's the people who will not admit to being a liar you must be most weary of, but I digress...
I have lied to law enforcement on multiple occasions (although I don't know how lying to them is significant compared with lying to anyone else). In this case though, my low-beam was indeed out, and I was using my high-beams to make my way home. I did omit the fact that my low-beam is also an HID, but the LEOs never had a problem with it before. As long as it's not aimed in their faces, they don't seem to care. Had I been asked if my low-beam was HID, I would have replied in the affirmative.
Would now be an inappropriate time to also admit to having illegal license plate, turn signal, and brake lights?
Is it also inappropriate to bring up this admission from mcrews' own profile:
FALL 2010:
2002 Q45 Sport w/ IMPUL body kit, 2005 Headlamps blackedout w/ Advanced Automotive Concepts Halos.
1. You drive an aesthetically altered Japanese import (ricer?)
2. You have blackout headlamps. Illegal in most states including CA.
3. Are halos DOT approved? I think not.
Pointing out hypocrisy does not invalidate a claim, but it does make you question the motives and values of the person making the claim.
