Old 04-13-2016, 11:10 PM   #21 (permalink)
Ford Prefect - '18 Ford F150 XLT XTR
Tess - '22 Tesla Y LR
Example from 4160V vfd, 105 amps continuous
Smaller crimps on 5KV rated cable
https://www.flickr.com/photos/141097.../shares/5kez6P
The crimps appear to start at least 1/4 inch from the edge and from the end of the lug
The visible parts of the bus show as copper. The plating appears to be tin?
Old 04-13-2016, 11:16 PM   #22 (permalink)
1600 amp horizontal bus, 600 amp vertical bus
This 600V switchgear has 1600 amp bus. The bars are braced for 65,000 amp faults (structure)
The 600 amp vertical bus looks a bit puny by comparison
This has nothing to do with crimping .. the equipment is being de-commissioned so I took the opportunity
https://www.flickr.com/photos/141097.../shares/Hi8Zh3
Old 04-15-2016, 12:47 PM   #23 (permalink)
Buss bars are welcome here.
Old 02-21-2022, 04:08 PM   #24 (permalink)
Wego connectors: "For those in a hurry to burn your house down" I salute you.
With all the electric cars being sold and home charges being installed this seems relevant.
https://youtu.be/zgjo36-jaFY
I have seen them used in industrial settings for years and my conclusion is they aren't worth a beaver dam. For communication and signal wiring they're fine for power wiring no, use wire nuts or or any of the above. Always follow code.
freebeard (02-21-2022)
alumiconn, polaris, ring terminal, split bolt, terminal lug
