Old 10-05-2017, 10:29 PM   #1 (permalink)
2015 WRX - '15 Subaru WRX
90 day: 29.18 mpg (US)
High flow cabin air filter for reduced blower motor load
I just realized that my blower motor is rated at 300W at full speed (higher than my two 120W radiator fans combined). This is a pretty significant draw at lower speeds around town. Removing my moderately-soiled cabin air filter seems to increase the air flow by quite a lot. If I can reduce the blower motor power by ~50% by removing the filter, or getting a high-flow cabin air filter, I figure that would result in a pretty decent gain in fuel efficiency.
This guy over at TDI forums replaced his air filter with some pantyhose over a mesh frame. I'm looking for a more traditional solution. Anybody know of any high flow cabin air filters available?
Lean burn baby!
Old 10-05-2017, 10:48 PM   #2 (permalink)
EcoModding Newb
90 day: 31.25 mpg (US)
Lafawnda - '01 Honda CBR600 F4i
Big Yeller - '98 Dodge Ram 2500 base
Prius Plug-in - '12 Toyota Prius Plug-in
90 day: 79.06 mpg (US)
Mazda CX-5 - '17 Mazda CX-5 Touring
90 day: 28.29 mpg (US)
I'd just knock a hole in an old filter. You'll never save as much in fuel as you spend on a new filter.
Old 10-06-2017, 01:03 AM   #3 (permalink)
I don't know about any high-flow cabin filter, but would rather resort to that makeshift with a pantyhose instead of running no filter at all.
Old 10-06-2017, 03:24 AM   #4 (permalink)
V8 guy
The more air a blower moves the more power it draws so putting in a high flow filter or removing the filter will make it use more power.
The only way it would use less power is if you put it on the high setting before and now you only turn it to the second highest setting with the high flow filter.
Old 10-06-2017, 05:12 AM   #5 (permalink)
Since there would be a lesser restriction to the air flow, it doesn't seem so likely to require more power to blow that greater air mass.
This sounded to be the case.
Old 10-06-2017, 06:21 AM   #6 (permalink)
JockoT's Avatar
All That Jazz - '06 Honda Jazz i-DSI S
90 day: 48.72 mpg (US)
Except then you would be dissipating the extra power across the blower resistor.
People Think They Are Thinking When They Are Merely Rearranging Their Prejudices
Old 10-06-2017, 07:13 AM   #7 (permalink)
V8 guy
The resistor isn't used when on the highest setting.
Old 10-06-2017, 10:18 AM   #8 (permalink)
JockoT's Avatar
No. But it is (and consumes power) when you choose a lower setting.
Old 10-06-2017, 12:07 PM   #9 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 32.65 mpg (US)
And here are some measured numbers from my truck: Electrical power draw
The heater blower draws less net power at lower speeds because the decreased power from the motor is much more than the increased power into the resistor.
The vacuum gauge plus wheel covers helped increase summer 2015 mileage to 38.5 MPG, while summer 2016 mileage was 38.6 MPG without the wheel covers. Drove 10,708.4 miles in 2017 at 35.5 MPG.
The Following User Says Thank You to JRMichler For This Useful Post:
JockoT (10-06-2017)
Old 10-06-2017, 01:21 PM   #10 (permalink)
Got MPG?
The Car - '09 Toyota Corolla CE Enhanced
K&N makes cabin filters now.
Never have to buy another cabin filter again....
2009 Corolla CE Enhanced - 1.8L auto
350K kms
Lifetime : 6.111L/100km (38.761mpgUS)
EPA : 6.8L/100km (34.6mpgUS)
14lbs Prius rims, full upper grill block, partial front belly pan, folded mirrors, lowered 1.5", LRR tech tires.
Copyright ©2000 - 2018, vBulletin Solutions, Inc.
