Old 02-05-2012, 07:38 PM   #11 (permalink)
oldschool
Olympiadis's Avatar
White2003Focus - '03 Focus SE 4-door sedan
Team Ford
90 day: 38.53 mpg (US)
White2001S10pickup - '01 S10 extended cab LR
Last 3: 24.51 mpg (US)
1989DodgeOMNI - '89 Omni
Last 3: 30.38 mpg (US)
1991ChevyC1500pickup - '91 C1500
Last 3: 24.03 mpg (US)
White1986Irocz - '86 Irocz LB9
Last 3: 30.14 mpg (US)
I would also like to hear an update.
Have you tested it yet? back in country?
Old 02-15-2012, 12:32 PM   #12 (permalink)
V8 guy
Sub - '84 Suburban C10
Pickups
camaro - '85 Camaro Z28
Lately I am putting together one of the simplest and most consistant and tuneable water methanol injection systems any one has ever seen.
I have a steady local source of 80 proof water methanol. I ran some numbers and figured out that for constant spary I want no more than 3gph and no more than 10% alcohol.
DIY Water Mist Injection system install, w/pics (MPG Boost Project) - Page 27 - Diesel Place : Chevrolet and GMC Diesel Truck Forums
Go back a few pages for my water injection system pics.
Water injection - EcoModder
Built an intake adaptor to try and use what I believe is the more efficient of the 5 factory intake manifolds made for the 6.2L/6.5T engine serries.
The problem is that intake manifold is set up for N/A use and I am trying to run a turbo ready intake for testing.
F-code/J-code adaptor - Diesel Place : Chevrolet and GMC Diesel Truck Forums
I removed dirty stained 2nd row seats, 75lb.
And I bought some .100'' aluminum dimond plate to do a 7 inch air dam just below the bumper.
And I have come to the conclusion I need to trade my brand new 31'' yokohama AT-S tires for some 31'' General LLR HT-S (highway tires).
I am down 7mpg from my all time high. This is where I think I am losing MPGs:
Winter -2 to -3 mpg
Going from sea level to 4400ft, -1 to -2 MPG (nothing can fix that)
Going from worn 31inch good year RT-S tires to new yoko 31inch AT-S tires -2mpg (confirmed by friend who did the same swap)
Switching from my ram air fed J-code intake manifold to the turbo ready F-code intake manifold. -2mpg (didn't know what was going to happen when I did this)
1984 chevy suburban, custom made 6.5L high compression diesel.
New engine is in and should be good for 29mpg highway.
1985 chevy camaro mostly stock.
Old 02-15-2012, 02:12 PM   #13 (permalink)
2004 CTD - '04 RAM 2500 SLT
90 day: 21.37 mpg (US)
Thanks for the links. Good reading.
2004.0 7,360-lb DODGE Ram QC/LB 2500 2WD/6-speed Cummins 305/555 ISB. Stock, except LEER bed topper and twin muffler exhaust. 180,000 miles at 4,625-hrs @ 39 mph. 15-cpm solo, 25-cpm towing. (22-mpg avg past 37k)
Fuel Log
Old 02-17-2012, 09:33 AM   #14 (permalink)
Interested to hear what you end up with when it's all sussed out and finished. Though I suspect this is one of those projects that'll never be "finished" per se.
2001 Prius - 170,000 KM - just got it (no consistent FE numbers yet)
Old 02-17-2012, 01:03 PM   #15 (permalink)
V8 guy
Pickups
On the list I have:
LED lights (in the process of installing and finding more)
A few aero mods (working on the 7 inch air dam today)
Water mist injection (has to be done before it warms up)
Upgrade to a more powerful electric coolant pump (has to be done before summer)
Install tachometer (before spring)
Convert to LiFePO4 batteries (done before I can turbo)
Install an air compressor system (done before I can turbo)
turbocharging
Regear the diff from 3.08 to 2.83-2.93 (after the turbo)
Build and install a custom 6 amp solar panel on the roof and find a LiFePO4 charge controller
Get a set of general grabber HT-S 31 inch LLR tires (sometime this year would be nice)
Electric clutch for the P/S-hydroboost brake system
Old 02-21-2012, 11:42 AM   #16 (permalink)
V8 guy
Pickups
Replaced all the bulbs I could with LEDs they had at Love's truck stop and autozone.
Ordered everything else I needed from superbrightleds.com.
Now anyone can very clearly see my brake lights during the day even when driving towards the sunset.
Blinkers still blink normally, will see what happens when I replace the A1157 bulbs up front with LEDs when they come in.
Added a "G4 halogen replacement LED array" next to the back up 1156LED replacement I installed, now I can see what is behind me when backing up at night.
May use a "G4 halogen replacement LED array" for licence plate lighting also.
I am trying to increase the feasability of running an alt delete or field winding intruptor.
Old 02-21-2012, 06:25 PM   #17 (permalink)
LED's are on my list. As are a pair of these. One for the truck rear bumper, and one for the trailer rear bumper. Switched at the unit for those long days on the highway.
Fuel Log
Old 02-22-2012, 02:04 PM   #18 (permalink)
V8 guy
Pickups
My trailer has LED tail lights and they are so much brighter than the trucks running lights and tail lights.
Now they are pretty close.
Just realized all the amber running lights on the trailer are not LED. Hope fully autozone will get in some more of those amber LED 194 replacements. I cleaned them out last time I was there.
Old 02-27-2012, 12:04 PM   #19 (permalink)
V8 guy
Pickups
I got the turbo ready J-code intake manifold on with intake heaters and installed my small solar panels this weekend.
Old 02-27-2012, 02:19 PM   #20 (permalink)
Eco-ventor
Princess - '92 MX-3 GS
House of Tudor
90 day: 33.52 mpg (US)
Send a message via MSN to jakobnev
With such a high static compression and a turbo, have you considered fiddling with the intake valve timing to bring down the dynamic compression?
Remember, even if you win the rat race - you're still a rat.
2010: 454.92L for 5313.90km => 8.56L/100km (27.5MPG US) (5 months)
2011: 606.11L for 7754.04km => 7.82L/100km (30.1MPG US) (Full year)
2012: 170.10L for 2405.00km => 7.07L/100km (33.3MPG US) (In progress)
