Old 10-07-2011, 10:51 PM   #11 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...what Frank Lee said.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 10-08-2011, 04:25 AM   #12 (permalink)
Absent without leave.
Arragonis's Avatar
George - '011 Aygo Go!
Team m8
90 day: 54.54 mpg (US)
Mildred - '011 Prius T-Spirit
90 day: 45.97 mpg (US)
You should be able to get 5th at 30 with no lugging. No climbing hills or overtaking but it should be cruisable at that speed.
I would check the linkages etc. and sort out that slow return to idle, if thats what it is.
Other than that taller tyres will increase gearing but your speed will be off.
No longer here. Bye, and good luck to all.
Old 10-13-2011, 03:19 AM   #13 (permalink)
Ethanol Fan
Mr. Fox - '91 Mustang GT
90 day: 15.99 mpg (US)
The older cars have taller ratios, I believe. Have you tried the Focaljet? They have info on the various transmissions with final drives. You're still looking at a transmission swap unless you're willing to tear apart the setup for the final drive.
The only 6spd is on the SVT, and it is a close ratio gearbox. The 5spds have wider gearing and taller OD.
~Allch Chcar
Old 10-16-2011, 11:21 AM   #14 (permalink)
royanddoreen's Avatar
The Rig - '010 glk 350 4matic
90 day: 24.01 mpg (US)
z - '03 350z touring
90 day: 28.98 mpg (US)
Oh my God, It just blows me away to see this high rpm problem this day. I mean a transmission should give us power and economy duh!! I can,t think about changing out my transmission or even my final drive ratio.I guess we soon will be able to pick up good used high mileage cars as they become more popular.I love my 350z my rpm is about 2500 at 60mph and I wish it was 1500.Its the only fault I see in the car.
Old 02-03-2012, 01:42 PM   #15 (permalink)
XJ Cherokee - '00 Cherokee Sport
FoFO - '011 Focus SE
This is a huge thread bump but ... I'm wondering if he isn't using 5th gear?
55MPH on my focus is a bit above 2000. I don't have exact figures, but 75mph is about 2800 or so. 80 is right around 3k.
Mine has slightly taller gearing ... but not much.
The difference is something like 3.37 to 3.45 (completely made up numbers). The MTX75 in these is not an overdrive trans and uses a higher "rear end" ratio to make up for it.
But still, 3000 at 65 is absurd.
Old 02-04-2012, 01:49 PM   #16 (permalink)
Ethanol Fan
The first few years the Focus had two engines with different axle gears. A SOHC and the DOHC Zetec. The SOHC had 3.65 gears while the Zetec has 3.82 gears.
The 2005 ZX3 had taller tires(865RPM@60) too, so I get 2750RPM at 65mph for stock gears and tires. I'm guessing someone installed 4.1 gears. Either way, a set of 3.65 gears from the base engined cars would be what you want.
2000-2004 Focus LX gears
2000 Focus ZX3
Then in 2005 they installed the Duratec in all the Foci. Transmission gearing changed but the axle gears were the same numbers as the previous Zetec.
2005 Focus
And Miller88, you are incorrect about the MTX75, it is infact an OD gearbox.
~Allch Chcar
Last edited by Allch Chcar; 02-04-2012 at 02:02 PM.. Reason: Edit, forgot that the stock tires changed for the ZX3
Old 02-04-2012, 07:10 PM   #17 (permalink)
I stand corrected. I'm trying to figure out where I saw the chart that said 5th gear in the MTX75 was 1:1 ... odd.
Old 02-05-2012, 03:58 PM   #18 (permalink)
tru
tru - '05 Focus ZX3
90 day: 39.46 mpg (US)
the truck - '02 Sierra Denali
i assure you i was in 5th, but my rpm's may not have been exactly 3k...I will report back next time im out
Old 02-06-2012, 12:05 PM   #19 (permalink)
tru
tru - '05 Focus ZX3
ok around 2700 at 65mph this morning
Old 02-06-2012, 12:49 PM   #20 (permalink)
Ethanol Fan
Sounds about right. It's surprising how efficient the newer aluminum DOHC engines, like the Duratec, are at the high RPM they typically cruise. The Automatics have a taller OD but high 2ks is typical for cars with a manual, especially from those pre-Katrina years.
~Allch Chcar
