Old 08-10-2010, 10:44 PM   #11 (permalink)
Ohh snap
brucey's Avatar
Lesbaru - '00 Outback
90 day: 21.98 mpg (US)
Convertalier - '00 Cavalier Z24 Convertible
90 day: 26.08 mpg (US)
Send a message via AIM to brucey
I still think with cars with power to spare, hills can actually increase mileage with proper technique. I'll do 95 mph down them, and 55 mph up them in top gear (god bless the third lane) and this mileage usually bests my flat land mpg by a few%.
I'm going to have to try to see a measurable difference with extra weight, as I also feel if it has power to spare, it can essentially have a bigger 'battery' with more weight. (More kinetic energy stored in the mass of the car)
Or maybe I'm just crazy.
Daily Driver
Winter Beast
Old 08-10-2010, 10:45 PM   #12 (permalink)
4way stop signs at the bottom of hills should be outlawed.
Old 08-11-2010, 12:20 AM   #13 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
You're not crazy, Brucey, you just have power to spare and a four speed tranny.
Driving a mile at 95mph, then a mile at 55mph results in 7% more aero drag than just driving 75mph. 7% is quite a lot, but evidently the Subaru gains more 7% with DWL instead of cruise control.
Old 08-11-2010, 09:57 AM   #14 (permalink)
comptiger5000's Avatar
The Beast - '98 Grand Cherokee (ZJ) 5.9 Limited
90 day: 14.58 mpg (US)
I don't do a ton of long highway trips, so I don't know if hills do better than flat ground in the beast, but I'm pretty sure they're not worse.
However, compared to the 4.0 I6, I get the same or better mpg on the hills, although it can beat me by 1 or 2 on the flats due to the displacement difference. It definitely helps to be able to pull at a hill at 50 in top gear turning 1500, or even 60 turning 1800, while the 4.0 would have to downshift a gear at any speed on most hills, meaning it would be turning 2100 at 50, or a bit over 2500 at 60. In these not-so-efficient old school engines, the extra RPM loses to the extra displacement.
Call me crazy, but I actually try for mpg with this Jeep:
Typical driving: Back in Rochester for school, driving is 60 - 70% city
Old 08-11-2010, 09:57 AM   #15 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...also, derisively, called "Mexican Stand-Off Signs"
Old 08-14-2010, 11:36 PM   #16 (permalink)
Northern most ecomodder
reddxhatch - '95 Civic DX
90 day: 46.04 mpg (US)
there are a couple kinds of hills some are good some are bad.
slightly hilly roads up and down. help pulse and glide remain at a steadier speed so as to annoy other drivers less.
only round trips count for the next statements
bad hills are so steep, or have obstructions at the bottom so as to require the use of brakes. glide down engine off then waste energy with brakes. then on the drive up low MPGs
good hills are steep enough for steady speed engine off then can coast down or continue on your way. On the way back up if you can get better than half your flat ground MPG then your doing well.
I can think of quite a few of both types of hills in my area.
Learn from the mistakes of others, that way when you mess up you can do so in new and interesting ways.
One mile of road will take you one mile, one mile of runway can take you around the world.
Old 08-14-2010, 11:47 PM   #17 (permalink)
Here in the Northeast I've heard of these referred to as being the "Sicilian stand-off".
Old 08-14-2010, 11:51 PM   #18 (permalink)
Originally Posted by brucey View Post
I still think with cars with power to spare, hills can actually increase mileage with proper technique. I'll do 95 mph down them, and 55 mph up them in top gear (god bless the third lane) and this mileage usually bests my flat land mpg by a few%...
...Or maybe I'm just crazy.
You are more lucky than you are "crazy".
You're lucky that the cops aren't around when you're goin' 95...
Old 08-16-2010, 02:02 AM   #19 (permalink)
Ohh snap
brucey's Avatar
It's relative.
In some places 5 mph over is a big deal, but on those stretches of interstate through the mountains I've been passed by semi's while I was doing 90 mph. Not that I'm advocating speeding, it's just when the flow of traffic is doing 20 over the limit anyway, what are you going to do?
Daily Driver
Winter Beast
Old 08-16-2010, 06:15 AM   #20 (permalink)
Vulcan - '05 Vulcan 500 LTD
90 day: 60.08 mpg (US)
Mag Pearl - '011 Fiesta SE Hatch
90 day: 45.91 mpg (US)
Toss it in neutral a grab a 4 or 5 stripe draft, use 5th gear DFCO and AC if you need to slow down.
I have seen downhill grades of 7% for several miles around Blacksburg Va, probably a lot like WVa.
Ever gone downhill on a two lane at speeds that scare you with a logging truck on your arse?
Slow down and die.
Hit your brakes and become a postage stamp.
Those guys are CRAZY!
regards
Mech
hills eoc
Serpentine belt squealing- I might have some good advice Frank Lee DIY / How-to 33 05-08-2012 12:33 PM
Are good used cars going up in price? Ryland Off-Topic Tech 24 05-30-2011 11:19 PM
40MPG with 97 metro - good or bad ? chris82369 General Efficiency Discussion 4 02-27-2010 12:59 AM
Are hybrid SUVs a good or bad thing? SVOboy Hybrids 36 04-01-2009 03:48 PM
Good 12V battery chargers Daox Fossil Fuel Free 8 03-16-2009 09:38 AM
