Old 09-28-2016, 09:39 AM   #11 (permalink)
90 day: 40.51 mpg (US)
Right, I imagine this helps fill the low pressure zone in the wake, but it probably also does it in a very turbulent manner. A kamm or boat tail + belly pan would be ideal, but there are plenty of situationally effective less than ideal solutions.
Old 09-28-2016, 01:25 PM   #12 (permalink)
JRMichler's Avatar
Nameless - '06 GMC Canyon
90 day: 37.45 mpg (US)
22 Maverick - '22 Ford Maverick XL
90 day: 42.77 mpg (US)
Were the before and after tests on the same road in the same direction with the same wind and same air temperature?
The Following 3 Users Say Thank You to JRMichler For This Useful Post:
compdrag (09-29-2016), mcrews (09-30-2016), Xist (09-29-2016)
Old 09-28-2016, 03:31 PM   #13 (permalink)
24 Grom - '24 Honda Grom
90 day: 121.34 mpg (US)
Yes they were
Old 09-29-2016, 03:19 PM   #14 (permalink)
90 day: 29.44 mpg (US)
Bell mouths and ducts
Old 09-29-2016, 05:13 PM   #15 (permalink)
Well just a quick update, I don't drive a whole lot so everyday I get more on the tank is a good thing. So I'm at around 280 now and still above a 1/4 of a tank. My UG will be here tomorrow so I will be able to do runs with cruise control to see what the differences are with and without the holes. Stay tuned!
Old 09-29-2016, 05:58 PM   #16 (permalink)
Do go on...
Old 09-30-2016, 04:36 PM   #17 (permalink)
Ok first round of numbers are in, and let me say I'm not saying the holes did it, but numbers don't lie. I will be repeating the test just not today. Ok I did two runs once with holes and one without. I used Duct tape to cover up the holes with multiple layers to unsure no wind got through. I took the same route and I went 60 mph for both tests. I neutral coasted on both off ramps and did 3k shifts when getting back up to 60mph.
Here is the start of the test notice the 0 in the trip gauge.
Here is after the first test 38.2 MPG with holes.
Start of 2nd test zero'd out.
Here is after the 2nd test at 37.6 MPG
ok now onto the performance gains I know its not as big of a deal I will be doing this test again also. I did not make it to 100mph like I wanted to only got up to 80 and then shifted to 5th getting back to 60mph quickly
run without holes
Run with holes gaining about .45 tenths of a second on speed and .3 tenths on 1/8 of a mile 1/4 I wouldn't count because I wasn't there by the time I hit 80.
The Following 3 Users Say Thank You to compdrag For This Useful Post:
aerohead (10-01-2016), BamZipPow (09-30-2016), niky (10-02-2016)
Old 09-30-2016, 04:38 PM   #18 (permalink)
oh on another note I'm at 370 miles on the tank, and I still haven't hit the fill light yet which is where I fill up at so i'm looking at probably 33 mpg by the time it does. After getting the UG I've be able to get 36mpg after a 60 mile trip.
The Following 2 Users Say Thank You to compdrag For This Useful Post:
Old 09-30-2016, 04:54 PM   #19 (permalink)
T-100 Road Warrior
BamZipPow's Avatar
BZP T-100 (2010) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 24 mpg (US)
BZP T-100 (2011) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 23.66 mpg (US)
BZP T-100 (2009) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (2012) - '98 Toyota T-100 ext cab - 3.4L/auto SR5
Last 3: 25.45 mpg (US)
BZP T-100 (2013) - '98 Toyota T-100 SR5
Last 3: 25.79 mpg (US)
BZP T-100 (2014) - '98 Toyota T-100 SR5
Last 3: 23.18 mpg (US)
BZP T-100 (2015) - '98 Toyota T-100 SR5
Last 3: 23.85 mpg (US)
BZP T-100 (2016) - '98 Toyota T-100 SR5
Last 3: 17.62 mpg (US)
BZP T-100 (2017) - '98 Toyota T-100 SR5
90 day: 20.78 mpg (US)
BZP T-100 (2018) - '98 Toyota T-100 SR5
90 day: 20.19 mpg (US)
BZP T-100 (2019) - '98 Toyota T-100 SR5
BZP T-100 (2020) - '98 Toyota T-100 SR5
2012 Scion iQ - '12 Scion iQ Base
Send a message via ICQ to BamZipPow
I noticed yer running open loop?
Dark Aero-The world's first aerodynamic single wheel boat tail!
Old 09-30-2016, 05:01 PM   #20 (permalink)
Its only open because the car was not running when I took the pictures. I didn't want to sit idling while I reset the trip and snapping the photos, and adding and removing the tape.
BamZipPow (09-30-2016), PaleMelanesian (10-19-2016)
