Home Brew Challenge for Electric Geniuses (make a DIY electric motor controller)
You know what would be really cool? ....
This friday i will likely be spending less than $100 on a very large motor. But to get my EV to go far and fast enough to make me happy, I will have to learn about batteries and Controllers... The dollar markup on Motor controllers that handle large volts and amps is amazing. Most likely, if you built one yourself (programmable or not) then you would save more than 1/2 the money. (simple supply/demand for large controllers is probably the biggest reason for the cost) What would be really cool is if some brains on this forum came out with an open source controller that you could build using electric parts bought from Radio Shack or Fry's Electronics that can serve EV means. For those of us hoping to build or convert a vehicle to EV - or to add in a electric motor for home brew hybrids - the cost savings would be enormous. Also, by having something such as this open source, new members who are electrically inclined may decide to attempt to improve the design once they join resulting in multiple versions that eventually would be sufficient for what ever an EV Builder's needs may be. Now, as most of you aware, I know crap about electricity. (i'm still considering taking a little 12v motor i pulled out of a toy car and hooking it up to my car's battery to see how long it can last on 500CCAmps) Now that I've tossed the idea out there (i mean, for a home brew EV Motor Controller. not for blowing up a toy motor) I would like to know if anyone in the community would like to step up and consider tackling this challenge (either alone or with other forum members) to make this a reality. While you consider, here are some example links I found for smaller controller schematics and information that may be useful: Link 1 Link 2 Link 3 Link 4 Link 5 Link 6 Link 7 Will anyone step up and attempt this challenge? |
I don't want to be a naysayer. OK, yes I do! No. Really...
But the largest assembled brain trust on the subject of EV's is the Electric Vehicle Discussion List: http://evdl.org for info. The subject of open source home brew controllers comes up every other month on the list, usually suggested by someone who wants to do a conversion, but doesn't want to (or doesn't have the means to) fork over the beans for a commercial controller. In the 2 years I've been reading posts there, nobody has yet made one. The challenges are serious, when you consider the job a controller has to do and the environment it has to do it in, and the consequences of something going wrong with it while & where it's being used. And it's not for lack of smarts. The number of really smart people on that list is astounding. The fact that a bunch of really smart & experienced people haven't yet made an open source controller that anyone can build for less money than a commercially produced one tells me something. Not saying it can't be done. But since I'm not an EE with time to spend on the problem, instead I continue to haunt eBay regularly watching for a bargain on the unit with the specs I'd like to have... |
And BTW, you don't necessarily need to start with a PWM controller. Electric vehicles of all sorts used contactor controllers for most of last century before the solid state electronics came along to do the PWM magic.
Have a look at Ryland's Citicar thread for info on that type of controller. |
No offense taken from your NaySaying. :)
BTW, when I buy/find a working controller, I plan to open the baby up and - if permitted by the various EM Mods here - post up a schematic of how it works. If nothing else, maybe it'll be a good starting point for people to home brew on the subject (if there isn't already an Open Source controller posted up by then.) I just find that paying up to $2000 for a controller to be disgusting when they are made by employees who are only paid $0.50 an hour in china. (or some other ridiculous number) EDIT: we were both posting at once. Yes, That is one thing i'm looking into. Infact, an open source contact controller schematic is one of the links i posted up. |
What are the specs required for a PWM controller?
I have built PWM systems for a few things, I have built computerized nitrous controllers, r/c car stuff, and other dc motor controllers. The PWM part is easy, The high current capacity can get expensive though. But it should still only be a few hundred bucks even for some really expensive mosfets. |
(looks around and finds the motor that didn't work) Quote:
Just as an example - that motor on the controller's output with 2 car batteries in series equaling 24 volt 750Amp DC input (a ballpark of car battery amps) could you do something for a motor like that? (no shame if you say it's over your head.) Myself, i'm getting a larger motor this weekend so the controller wouldn't be much use to me. but it'd be a good test for you to see if you can figure it out. edit: LINK this is a simple PWM controller for a small fan. |
87 amps would not be that hard but 750 amps would take some really big wires :) I thought most electric cars had stuff like 4ga wires going to the motor. With that many amps it would need something like 00ga.
Ill have to look around and see what I could do to make a fet bank that can handle 750 amps. That would be probably big and a pain to build for a normal hobby type of thing though. |
I could be wrong, i've never completed an EV Before and am still collecting parts for my first attempt.
Image from EVA/DC http://www.evadc.org/images/wiring_diagram.gif |
I have some experience with RC PWM controllers but nothing in the realm of what you're talking about with that kind of current. In theory the design would be the same though, just with more robust parts really. It would seem that you could almost just reverse engineer an RC controller and find higher tolerance parts to substitute in for the ones in the existing schematic...no?
