Old 10-25-2015, 12:46 PM   #11 (permalink)
Growin a stash
Battery volts
(~5th post)
This probably falls under TMI, but here it is for those that might be interested.
2014 Chevrolet Cruze 2.0L Eng Diesel
Charging System Operation
The purpose of the charging system is to maintain the battery charge and vehicle loads. There are 6 modes of operation and they include:
Battery Sulfation Mode
Charge Mode
Fuel Economy Mode
Headlamp Mode
Start Up Mode
Voltage Reduction Mode
The engine control module (ECM) controls the generator through the generator turn ON signal circuit. The ECM monitors the generator performance though the generator field duty cycle signal circuit. The signal is a pulse width modulation (PWM) signal of 128 Hz with a duty cycle of 0-100 percent. Normal duty cycle is between 5-95 percent. Between 0-5 percent and 95-100 percent are for diagnostic purposes. The following table shows the commanded duty cycle and output voltage of the generator:
Commanded Duty Cycle Generator Output Voltage
10% 11 V
20% 11.56 V
30% 12.12 V
40% 12.68 V
50% 13.25 V
60% 13.81 V
70% 14.37 V
80% 14.94 V
90% 15.5 V
The generator provides a feedback signal of the generator voltage output through the generator field duty cycle signal circuit to the ECM. This information is sent to the body control module (BCM). The signal is PWM signal of 128 Hz with a duty cycle of 0-100 percent. Normal duty cycle is between 5-99 percent. Between 0-5 percent and 100 percent are for diagnostic purposes.
The BCM will enter this mode when the interpreted generator output voltage is less than 13.2 V for 45 minutes. When this condition exists the BCM will enter Charge Mode for 2-3 minutes. The BCM will then determine which mode to enter depending on voltage requirements.
Charge Mode
The BCM will enter Charge Mode when ever one of the following conditions are met.
The wipers are ON for more than 3 seconds.
GMLAN (Climate Control Voltage Boost Mode Request) is true, as sensed by the HVAC control head. High speed cooling fan, rear defogger and HVAC high speed blower operation can cause the BCM to enter the Charge Mode.
The estimated battery temperature is less than 0°C (32°F).
Battery State of Charge is less than 80 percent.
Vehicle speed is greater than 145 km/h (90 mph)
Current sensor fault exists.
System voltage was determined to be below 12.56 V
When any one of these conditions is met, the system will set targeted generator output voltage to a charging voltage between 13.9-15.5 V, depending on the battery state of charge and estimated battery temperature.
Fuel Economy Mode
The BCM will enter Fuel Economy Mode when the estimated battery temperature is at least 0°C (32°F) but less than or equal to 80°C (176°F), the calculated battery current is less than 15 amperes and greater than -8 amperes and the battery state-of-charge is greater than or equal to 80 percent. Its targeted generator output voltage is the open circuit voltage of the battery and can be between 12.5-13.1 V. The BCM will exit this mode and enter Charge Mode when any of the conditions described above are present.
Headlamp Mode
The BCM will enter Headlamp Mode when ever the headlamps are ON (high or low beams). Voltage will be regulated between 13.9-14.5 V.
Start Up Mode
When the engine is started the BCM sets a targeted generator output voltage of 14.5 V for 30 seconds.
The BCM will enter Voltage Reduction Mode when the calculated ambient air temperature is above 0°C (32°F). The calculated battery current is less than 1 ampere and greater than -7 amperes and the generator field duty cycle is less than 99 percent. Its targeted generator output voltage is 12.9 V. The BCM will exit this mode once the criteria are met for Charge Mode.
2024 Chevy Bolt
Previous:
2015 Nissan Leaf S, 164 mpge
The Following 4 Users Say Thank You to ME_Andy For This Useful Post:
BrandonMods (10-26-2015), oldtamiyaphile (10-26-2015), redpoint5 (10-26-2015), teoman (01-27-2017)
Old 10-26-2015, 09:21 PM   #12 (permalink)
Champagne - '13 Chevy Cruze 1LT
90 day: 33.35 mpg (US)
Thanks for all the information posted. This appears to be a much more in depth project. I like the idea of charging the battery overnight to reduce the alternator charge cycle(s).
I will research further and revisit with results. Thanks everyone for all your help.
Old 01-27-2017, 07:16 PM   #13 (permalink)
teoman's Avatar
A3 - '12 Audi A3
What if supercaps are constantly charged to 14.8v with an external battery.
Also where is battery temperature measured?
Old 01-27-2017, 07:29 PM   #14 (permalink)
teoman's Avatar
A3 - '12 Audi A3
Can the bcm signals be intercepted on the canbus? Or some other wire?
