Old 09-06-2009, 12:42 PM   #1 (permalink)
Honda Accord Factory Belly Pan/rear diffuser
FWIW
I thought it would be worth posting that there is a factory available partial belly pan and rear diffuser available for the Accord. It should definitely fit 05-07 and I believe that body configuration goes back to 03.
I have a 2007 Accord Hybrid and in addition to the extensive modification of the V-6 engine the engineers also added the above aero parts to the car.
The belly pans located between the front and rear axles in addition to smoothing both sides of the car also appears to lower that portion around 1.5 to 2 inches.
The rear diffuser seems to meet the requirements discussed here in Ecomodder and is also designed with strakes. Rear coverage could have been better on a car with less of a exhaust system (like the 4 cyl). Dual exhaust tubes with two large rear siliencers are part of the rear most underbody.
These parts were all done in a molded plastic of some type.
The Hybrid Accord was only produced from 05-07 and the numbers weren't great so the parts might be a bit tough to find used.
My vehicle also has a extensive pan under the front of the car. Don't know how that compares to the standard V-6 or 4 cyl on the Accord.
BTW that rear diffuser is probably the easiest way to spot a Accord Hybrid. You can see that long before reading the hybrid badge.
I don't drive it much but my car gets highway mileage in the 40's when the throttle actuator is properly programed so it would be interesting to have someone pop these parts on a 4 cyl or standard V-6 and see what they might contribute.
Cheers
The Following User Says Thank You to EVDRVR For This Useful Post:
SVOboy (09-06-2009)
Old 09-08-2009, 11:25 AM   #2 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
Got a pic?
Old 09-18-2009, 08:37 PM   #3 (permalink)
Looking under a car with very little clearance is one thing getting a useful picture is another. Will see what I can do.
Old 09-20-2009, 06:51 PM   #4 (permalink)
Chicago Suburbs Field Tech - '98 Accord LX
90 day: 35.09 mpg (US)
i'd be interested in trying to fit that on to my 98 accord! Pics would be nice. Might have to do some junkyarding.
Old 09-21-2009, 11:20 PM   #5 (permalink)
Yeah, I've been trying to find info on these pieces and can't find anything. I have an 05 Accord and want to add a belly pan. Can you give us a few more details on the pieces. Front belly pan, how far does it go back, does it go under the oil pan. Rear diffuser, is it part of the rear bumper or an add on piece underneath. Are their rear tire spats on yours? Any other aero differences you've found compared to non-hybrid version, other than tires rear lip spoiler and stuff you mentioned.
Old 09-27-2009, 10:56 PM   #6 (permalink)
04 Accord - '04 Accord EX
90 day: 34.48 mpg (US)
This conversation is truly worthless without pics. I need them to steal what uve got and put it on mine!
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Traded My Jeep For A New 2009 Honda Accord! rgathright General Efficiency Discussion 2 12-04-2009 08:06 AM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
Convert your Honda Accord to run on trash akashic Fossil Fuel Free 3 01-08-2009 09:41 PM
Free Factory Honda Manuals... justpassntime Off-Topic Tech 0 07-16-2008 05:17 AM
