Old 08-30-2008, 06:50 PM   #1 (permalink)
chilimac02's Avatar
Honda Alternator Switch
I'd like to know if any of you have installed an alternator kill switch. I have a Scangauge, so I'll be able to watch my battery's voltage. Also, what %mpg gain would I be able to expect from doing this?
I know andrew's white civic has an alternator cut, but there are no specifics about where/how to do it. I'm not the smartest with electricity... But I am a smart guy who understands how things work, so if I had a chart or instructions, I'd be confident that I could do it.
-Justin
Old 09-01-2008, 05:31 PM   #2 (permalink)
Tracy - '00 corsa
best/easiest thing to do, is buy a deep cycle battery 100ah and plug it into your cigarette lighter port. charge it from home with a decent battery charger. get a 14v or 16volt battery and it will prevent the alternator from switching on. be careful with current though -maybe by a watts up meter.
Peugeot 106 1.5L diesel. Average FE = 70mpg(UK)
Del:mirror/aerial/mudflaps. + grillblock
Old 09-01-2008, 07:35 PM   #3 (permalink)
chilimac02's Avatar
1) What is a watts meter?
2) Why would I want to plug it into my cig. Port? Wouldn't I want to mount it in the trunk, and then run a wire into the system that way?
3) Why would I get a 16V? My alternator peaks at about 14V
I'm not trying to sound too critical, I just honestly have questions about that...
Old 09-01-2008, 08:44 PM   #4 (permalink)
Tracy - '00 corsa
Alternator Delete VS starter motor
check out my system on this thread it should answer some questions
Old 09-02-2008, 12:00 AM   #5 (permalink)
chilimac02's Avatar
Gracias!!
I shall sort through it. I'm a little bit of a novice when it comes to electronics and schematics. It's been about 11 years since I took electricity and magnetism (physics)...
Old 09-02-2008, 11:03 AM   #6 (permalink)
Tracy - '00 corsa
i haven't tested it yet but im looking forward to it
accord, alternator cut, honda
Reviving a 2000 Honda Insight "beater" Red Hybrids 201 01-06-2012 12:42 AM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 01:59 PM
Places to get OEM Honda Parts TomO Off-Topic Tech 10 06-02-2009 02:56 PM
Honda as a green company - perception overshadowing reality? atomicradish EcoModding Central 11 07-19-2008 05:36 PM
Free Factory Honda Manuals... justpassntime Off-Topic Tech 0 07-16-2008 06:17 AM
