I'm now leaning towards the balance idea too. Here's why...
I got to thinking that every OEM rim now must have the TPMS sensors. They
have significant mass, yet my wheels on my Touring model Prius -- 7
spoke wheels -- do not have a bunch of balance weights opposite the valve
stem. The rim section of the wheel is apparently trued on a lathe, little
chance for asymmetrical thickness there.
So I looked/felt around the spokes adjacent to the valve, and the spoke
directly across from the valve.
Surprise! The webs on the back of the spoke somewhat thicker than those
adjacent to the valve. (Note: The spoke essentially has the shape of a
"C-section" beam, kinda' like this: [ with the wide flat web facing outward,
the two flanges inward.)
Maybe this is to balance the mass of the TPMS sensor.
It remains for others to do a similar check on their alloy rims to see if this
feature/construction is widely used.
Edit: I just realized the balancing material in the opposite spoke/s could
also be in the thickness of the web... harder to find/measure.
