Old 11-06-2010, 09:38 PM   #1 (permalink)
Red Rabbit - '02 Civic LX
90 day: 38.58 mpg (US)
Honda Civic defrost w/o A/C on
So apparently Honda thinks that the A/C needs to be on ALL the time when the defroster is on, as you are unable to turn it off while in defrost mode....
Until you do this
Works on 7th and 8th gen civics. Defroster works better with A/C on, but if you are just trying to keep it from fogging back up sometimes you don't need the A/C on to dry the air out.
The Following User Says Thank You to Schelter For This Useful Post:
endurance (11-08-2010)
Old 11-07-2010, 12:12 AM   #2 (permalink)
in tents
dennyt's Avatar
The Adventure Wagon - '94 Loyale Wagon 4x4
Subaru
90 day: 33.43 mpg (US)
Electro-Monkey - '011 Karate Monkey BMC V2S Front Hub Motor
90 day: 694.1 mpg (US)
Awesome. I just pull the AC circuit fuse in my Subaru Loyale, except for July-August.
Old 11-07-2010, 05:38 AM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Since I never got heat working back in my IRX, I just used a squeegee. I kept it right besides the fire extinguisher for easy getting-to.
Old 11-08-2010, 12:17 PM   #4 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
There are two wires that control the electric AC clutch. Splice an appropriatly heavy switch into one of them. Mount this switch in the cabin. It should allow you to turn it off when you don't want it on.
My dad had a compressor lock up in an old truck. He just unplugged the electrical connector on the compressor.
Converting Cali Civic VX to Fed (lean burn) VX NachtRitter DIY / How-to 52 05-18-2012 12:52 PM
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
honda civic- buying advice? robots4joey General Efficiency Discussion 18 03-26-2010 03:19 PM
'93 Civic 40.6 mpg + Harbor Freight utility trailer, Honda CL125, Honda CH80 scoot begreen Introductions 12 03-12-2010 12:23 AM
8th Gen. Civic manual defrost A/C control superchow DIY / How-to 0 02-02-2010 03:29 PM
