Old 08-17-2008, 10:48 PM   #1 (permalink)
Ecoformance Engineer
Vince-HX's Avatar
EJ7 - '96 civic Hx
Last 3: 58.02 mpg (US)
Honda civic fan speed control possible mod
This is a post about honda and their use of a resistor pack fan speed controller.
I found out about this little wasteful item halfway through a air conditioning mod. The little speed controller needed to be relocated to make way for some ducting and I actually burned myself on it on accident.
Anyway, on any speed other then full blast (4) the resistor pack is creating a good amount of heat. And do you know where that heat is going? Right into the air that you have on trying to cool off. The actual resistor elements are located within the blower fan shroud.
I'm really curious to see how many amps the blower is still pulling on lower fan speeds. Need to break out the multimeter.
Does anyone know where to locate a switching variable fan speed control so I can keep up efficiency on lower fan speeds? That would be the best solution I think. The control needs to have at least a 7.5 amp capacity.
Here is a nice little writeup on the control with pix.
Honda-Tech.com: Tech/Misc: Blower Motors Works on speeds 3/4 but not 1/2 - FIX + How-To
70 mpg or die modding
www.full-race.com
looking forward to seeing what kind of uber-sipper slinks out of the full race skunkworks.
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
1995 Honda Civic not so great highway mileage nasoj007 Hypermiling / EcoDriver's Ed 11 08-09-2008 07:11 PM
Cruise control mod idea rjacob DIY / How-to 18 07-29-2008 11:27 PM
Honda c70 Passport Mod: Take 3 - Restoration papaslides Motorcycles / Scooters 5 06-28-2008 04:16 PM
1991 Honda Civic 4 sale !!! Low Miles joemetro For Sale 2 02-22-2008 10:38 PM
