Old 06-13-2013, 10:46 PM   #1 (permalink)
mikeyjd's Avatar
Matchbox - '93 Ford Festiva L
Team Ford
Last 3: 70.16 mpg (US)
Salamander - '99 Chrysler Concorde LXI
Team Dodge
90 day: 30.3 mpg (US)
Urquhart - '97 Toyota Tacoma 4x4 V6 3.4L DLX
Pickups
90 day: 25.81 mpg (US)
Smudge - '98 Toyota Tacoma
90 day: 40.65 mpg (US)
Calebro - '15 Renault Trafic 1.25 dci
90 day: 39.39 mpg (US)
which honda civics meet these criteria
4door sedan
5spd
epa: 40+mpg
98 or newer
Budget $6,000
Old 06-13-2013, 11:07 PM   #2 (permalink)
Hydrogen > EV
Silver Flea - '05 Honda Insight
90 day: 58.96 mpg (US)
262 results in the United States.
Find Your Car: Honda Civic Listings Near Cleveland, OH 44129 - AutoTrader.com
Best Tanks:
Mustang - 54.83 mpg (US) at the Green Grand Prix
Insight - 82.91966 mpg (US) over 818.5 miles.
Old 06-13-2013, 11:35 PM   #3 (permalink)
Ryland's Avatar
90 day: 79.71 mpg (US)
Blue VX - '93 Honda Civic VX
Civic Hybrid is the only 4 door that I know of that gets over 40mpg and it's old enough now that it a 2003 civic hybrid blue books for $3,500
Old 06-13-2013, 11:38 PM   #4 (permalink)
Hydrogen > EV
Between seeing Team Honda, and my Mustang approaching 40, I am pretty sure any Honda can do it lol
Best Tanks:
Old 06-14-2013, 04:09 AM   #5 (permalink)
Ryland's Avatar
There is a difference tho between starting with a car that already gets 40mpg and starting with a car that gets 25mpg.
The Following User Says Thank You to Ryland For This Useful Post:
Daox (06-14-2013)
Old 06-14-2013, 12:47 PM   #6 (permalink)
Eco Sol
Shortie771's Avatar
If you drive smart, you should be able to achieve 40+ with just about any 4 cylinder Honda sedan. I have a 1994 1.6L Honda Del Sol Si 5 speed, it has probably the worst aerodynamics of any Honda car and it is also paired with the shortest (most sporty) gears that Honda offered then (that I know of). I have achieved 40+mpg with it by only having an EOC switch and changing my driving habits. I am 100% positive that you can achieve the same or better results with a newer, longer geared, more aerodynamic 1998+ sedan.
EDIT: Check craigslist in your area, there are tons of them.
http://grandrapids.craigslist.org/se...inAsk=&maxAsk=
Best Tank = 42.72 mpg (in the 94 Del Sol)
CR-Z Current Mods:
Max Sidewall PSI
Old 06-14-2013, 12:54 PM   #7 (permalink)
Hydrogen > EV
I agree, there is a difference between getting 40 mpg EPA estimated, and actually getting 40 mpg.
But OP did not specify if he wants to stomp the gas pedal and get 40 mpg, or drive smart and/or ecomod to get 40 mpg. Since he is here on ecomodder, I imagine driving smarter/modding are not out of the question-otherwise he would have asked in a Honda forum. Like shortie said, any Honda sedan that meets his criteria is a 40+ mpg car.
Best Tanks:
Old 06-14-2013, 02:36 PM   #8 (permalink)
Hypermiler
PaleMelanesian's Avatar
90 day: 69.2 mpg (US)
PaleFit - '09 Honda Fit Sport
Wagons
90 day: 44.06 mpg (US)
03-05 Civic Hybrid is the only one with 40+ epa rating and stickshift. You don't want that one. By now the batteries are failing and Honda isn't interested in replacing them.
Honda likes to short-change their manuals with higher-revving gear ratios. Still, any recent Civic stick will easily do 40+ mpg, just not epa rated as such. I mean, set the cruise control at 65 and you'll get it.
Old 06-14-2013, 03:17 PM   #9 (permalink)
Thalmaturge
The Tinyvan - '07 Honda Fit Sport
Bought exactly this car with a failing hybrid battery for cheap, replaced the hybrid battery for [relatively] cheap from Bumblebee Batteries... an easy DIY project. Flip the HV cut switch, take out about 20 screws, unplug the battery, plug in the new one, replace those 20 screws, flip on the switch, done.
I'm now enjoying an average of 52 mpg over the last 20k miles in a good sized 4 door car and a mostly in-town commute.
Buy a 2003-2005 Civic hybrid manual with a bad battery: $3500
Buy a new hybrid battery from Bumblebee: $2100
Gets you in under your budget and well over your target.
Sam
The Following User Says Thank You to samwichse For This Useful Post:
Ryland (06-15-2013)
Old 06-14-2013, 09:30 PM   #10 (permalink)
mikeyjd's Avatar
Team Ford
Team Dodge
Pickups
Thanks for that info.
Sam
good idea perhaps.
