Old 05-06-2009, 07:37 AM   #1 (permalink)
Honda CRX good for conversion?
Read about lots of EVs but not too many Hondas. Would a CRX or a Civic make a good conversion to electric vehicle? Is there a reason they are not preferred? I guess motor rotation has to be a concern. Are they different from the Metros which seem to be popular? Still looking for the right platform. Thanks for all replies.
rese
Old 05-06-2009, 08:31 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
There is a good handful of CRX conversions out there. Take a look on EV Album.
crx - Google Search
Old 05-06-2009, 11:34 AM   #3 (permalink)
Bicycle Bob's Avatar
Appliance White - '93 Metro 4-Dr. Auto
Last 3: 42.35 mpg (US)
Stealth RV - '91 Sprint Base
A friend of mine said he was going to convert his Civic after the engine wore out. I asked if he was planning to remove the oil, and he said "Ohhhh. . ." :-) The CRX sounds like a natural to me. Strong chassis, with a small, slippery body, except for it's value as a classic.
Old 05-06-2009, 02:25 PM   #4 (permalink)
Wonderboy's Avatar
CRXFi - '88 CRX HF / XFi
90 day: 38.84 mpg (US)
01 Insight - '01 Insight
90 day: 46.19 mpg (US)
I'm scoping out a base for an EV as well, and also looking heavily into using a CRX if I can. They are so stylish. The only problem I'm running into (and it's something I expected) is that as Bob mentioned - they are a classic. EVERYONE wants one to throw an engine swap into one. The one thing HP tuners and FE tuners have in common is the desire for a light body, and the CRX has it with style to boot. I found this site to be very comprehensive and resourceful on this matter. This is a nice informative site about just CRX. CRXs have just about the lightest curb weight out there, especially if you can find an HF (this is an even rarer find as it's the lightest CRX).
Things unmentioned on that EV site:
- '91-'97 corolla/prizm curb weight = 2315lbs.
- The curb weight of metro variants of especially early generations (Gen 1, '83-'88 weighed 1653lbs) rivals the curb weight of the CRX. And don't forget about the Subaru Justy!
Old 05-06-2009, 06:56 PM   #5 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
Unless you brake the timing belt on a crx or civic the engine will last well over 300,000 miles, metros not much past 200,000, both of them are much much less of course in the hands of a teenager.
the draw back of a CRX is the space for batteries, there is no rear seat to remove, there are no square chunks of space and if you put the batteries in the rear you have to put some in the front or it will make it so rear heavy that it will scare you to death to drive it, I found this while using my crx hf as a work vehicle hauling 200+ pounds of tools in the rear, if I didn't have a passenger it wouldn't handle well because the car is to light, if there was space between the rear axle and the seats that would be different, but there is no space.
Also, why take a solid car that with a perfectly good engine and can get 55mpg in it's stock form and convert it when you could leave it on the road for someone who does drive distances and take a car that only gets 35mpg off the road and convert it.
Old 05-06-2009, 07:03 PM   #6 (permalink)
Wonderboy's Avatar
I was actually kind of thinking of that too looking on CL for the very worst CRXs I could find. I didn't want to buy one with a running engine because I wouldn't want to waste it . Got any personal suggestions on cars that DESERVE conversion?
Old 05-06-2009, 07:15 PM   #7 (permalink)
Ryland's Avatar
well, if you can find a crx that someone already pulled the engine from and cut the wiring up while trying to make it a race car, then you might be able to get a good price on it and make it an EV, but like I said already, they handle very poorly with weight in the rear so your batteries need to be split with half in the front.
Old 05-06-2009, 09:18 PM   #8 (permalink)
Do you have Daihatsu cars over there? the Charades are around 1300lbs in the four seater variants. Basically any of the Japanese Kei cars would be good candidates.
Old 05-07-2009, 03:28 PM   #9 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 125.37 mpg (US)
U.F.O. - '00 Insight
90 day: 85.75 mpg (US)
Geebee - unfortunately, we don't have many lightweight cars. Not the Charade - or kei class. North America used to have small, light cars, but they're mostly gone to their graves by now.
A partial list of potential host cars I considered, from the ForkenSwift thread:
- 89-94 metro: 1650 lbs
- 84-87 civic: 1797 lbs
- 95-99 metro: 1830 lbs
- 94-97 aspire: 2004 lbs
Another consideration: resestop hasn't said what his goals are for the vehicle. If he's looking for something with range (ie. holding a lot of batteries), none of the cars we're talking about is appropriate unless he's going to use something other than lead acid batteries.
Old 05-07-2009, 04:33 PM   #10 (permalink)
2k2Prot5 - '02 Protege5
90 day: 33.82 mpg (US)
Is weight handling simply a matter of using heavier springs? It is VERY easy to source heavy springs for Hondas, maybe not so easy to source heavy springs that aren't lower than stock. 5, 10 even 15 times the spring rate is common in the race community from quality spring mfg's for cheap (300-400 bucks)
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Honda Insight Concept to Debut at Paris Int. Auto Show SVOboy EcoModder Blog Discussion 32 04-17-2009 10:45 AM
1991 Honda CRX - New Here... Hi, Everyone! adam62882 Introductions 4 09-28-2008 10:35 PM
Opinions: CRX HF, Honda Insight or Keep Suzuki Swift? dunhamjr General Efficiency Discussion 17 06-18-2008 05:14 PM
EV1 trivia: Honda CRX Si was inspiration MetroMPG Fossil Fuel Free 0 12-02-2007 08:50 AM
