Old 04-23-2009, 08:55 PM   #21 (permalink)
Bio Deezler - '03 Jetta GLS TDI
90 day: 50.78 mpg (US)
The internal combustion engine still has a lot of advancing to do before its completely discarded, for sure.
I don't see this technology ever making it to market though. Special pressured oil line through the crankshaft, rod, wrist pin and finally into the piston to actuate the VCR, with a separate external (in this case) oil pump? Pretty neat just that anyone ever pulls it off in a prototype test engine. This is not a new idea, but kudos for Honda to keep it alive and kicking. They should combine this idea with the variable stroke length concept:
Honda's variable stroke length engine
Old 04-23-2009, 09:57 PM   #22 (permalink)
Yeah as I was saying I think this was an initial scale test to decide if its worthy of more investigation or not. Looks like the answer is to test whether or not the system has survivability and manufacturing cost
Old 04-23-2009, 10:59 PM   #23 (permalink)
Deezler looks like you beat me too it. Definitely sounds way too complicated to put in mass market. Who knows they might drop a new HF on us with variable stroke length, compression, timing, GDI, and ultra-lean burn.
That would be a Christmas to remember!
Project: Rebuilding an '01 Honda Insight as a nonhybrid Fabio Hybrids 155 05-01-2012 09:33 PM
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Someone asks: How did I get 40 mpg (US) from an '89 Honda Accord? MetroMPG Hypermiling / EcoDriver's Ed 0 04-09-2009 05:52 PM
Variable compression engine reduces fuel use 30%? SVOboy General Efficiency Discussion 6 01-02-2009 09:10 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
