Old 02-19-2008, 10:04 PM   #11 (permalink)
budomove's Avatar
Ze Future Beam - '00 insight
90 day: 66.23 mpg (US)
insightcentral.net is your friend.
If you search the following, you will know as much as you need or want to know.
search i-c:
egr
transmission
clutch
balky
notchy
grind
2nd
cat
catalytic
lean burn
recal
forced charge
2000 Honda Insight 5spd Silver 63.9 lmpg
Old 02-20-2008, 09:11 AM   #12 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Originally Posted by NoCO2 View Post
Ok, well that's a lot of info guys, thanks a lot.
I found a few '00 model insights for around $5k - $6k and I'm talking to my dad this weekend about possibly trading in my Camry for one since the Camry has been having a lot of maintenance issues just due to it's age and I am trying to convince him that the increase in fuel efficiency is worth it for both myself and him since if it benefits him he's more likely to go for it. We will see how it goes, but again, thanks for the info, I want to be as informed about this going into it as I can so I can present a good bit of info for him.
I'd just like to point out, and you probably know this, but definitly get a 5 speed manual transmission as they have the learn burn. The automatics don't, and thus get much worse mileage.
Old 02-20-2008, 10:18 AM   #13 (permalink)
Bicycle Junky
NoCO2's Avatar
Putsaround - '96 Camry LE
90 day: 32.74 mpg (US)
The Commuter - '07 1000SL
90 day: 617.28 mpg (US)
Zippy - '91 Civic DX
90 day: 33.29 mpg (US)
Yea, I was definitely planning on getting the 5spd model. I'm going out this weekend to some of the Honda dealerships in the area as well to see if any of them have gotten some insights as trade-ins recently and have them up for real cheap. Is there anything to note about hybrids with high millage? Is there even any data as to the effects of higher millage on the components of hybrids? I'm sure the batteries should be replaced, but what other parts are known to go bad over time with these?
Mostly directed at budomove, what have you had to do towards your '00 in terms of servicing and maintenance recently if any?
Old 02-20-2008, 10:30 AM   #14 (permalink)
budomove's Avatar
go to insightcentral.
cleaned egr
flushed tranny
adjusted valves
changed plugs
watch for a grindy/hesitant to shift transmission, that is the deal breaker on the insight. the synchros in the trans wear easily, and the clutch is not as durable.
Old 02-20-2008, 10:59 AM   #15 (permalink)
H4MM3R's Avatar
Here is a write up on the insight. http://www.caranddriver.com/reviews/...s_by_make.html
After adjusting the "toe" to give the car a more stable feel. They lost some FE.
Old 05-06-2008, 07:36 PM   #16 (permalink)
That Car and Driver long-term review of the Insight was in 2002: C & D was using $1.15 per gallon as the cost of gas. It wasn't THAT low then, was it?
More like maybe $1.50?
thanks for the link
Honda IACV explained TomO Off-Topic Tech 10 11-25-2011 12:59 PM
Places to get OEM Honda Parts TomO Off-Topic Tech 10 06-02-2009 01:56 PM
