Old 10-05-2009, 09:03 PM   #11 (permalink)
6 speed Diesel FTW!
The Golf - '02 Golf GLS TDI
Diesel
90 day: 63.94 mpg (US)
Mongoose - '05 E-bike AWD
90 day: 1810.34 mpg (US)
Send a message via AIM to dremd
FYI: the the spacer has to do with Pulse tuning.
Essentially alows you the adjust (slightly) the peak efficiency area of the intake.
6 speed ALH TDI
Old 10-05-2009, 09:29 PM   #12 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Spacers and this honeycomb thing are two different things.
Old 10-05-2009, 09:46 PM   #13 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Those tires/lift are probably why your mileage is so poor. The original was rated at 22 30 25 (city highway combined), and adjusted to 20 23 21 for the window sticker so 20+ should be possible. The best bang for your buck is installing a rear end from a carbed M4 2WD of the same year/s. It was rated for 30 40 34 unadjusted and 27 31 29 adjusted.
Old 10-15-2009, 07:02 PM   #14 (permalink)
honeycomb
I think that once the mixture is through the venturi,past the throttle plate,and into the plenum of the intake manifold,it's got plenty of turbulence to help entrain any droplets that might be present,and the whole charge will be blasted to smitherines, once past the intake valve and into the combustion chamber.
I suspect that the honeycomb would only serve as a restriction and might actually interfere with some of the charge' ability to turn down the runners.
A normal spacer ( which is wide open ) adds length to the plenum,which aids in "turning" the charge along a larger radius and can help prevent "wet out" on the floor of the plenum,something the matrix of the honeycomb might aggravate.
I'd shy away from the device.
Old 03-04-2010, 08:17 PM   #15 (permalink)
go to www.mpgresearch.com and search for screen under carb. Or,http://www.gofastnews.com/board/engi...b-booster.html
Old 03-05-2010, 02:26 AM   #16 (permalink)
Don_Kendons_Intake_Scrolls : Don_Kendon's_Intake_Scrolls
Old 03-08-2010, 08:10 AM   #17 (permalink)
EcoModding Alien Observer
suspectnumber961's Avatar
highcountryexplorer - '86 720 KC 4x4 ST with fiberglass cap
90 day: 20.51 mpg (US)
Elroy - '03 Focus ZX3 w/Zetec DOHC engine
90 day: 32.27 mpg (US)
Here is something from mpgresearch.com....
85 22R Toyota carbed ...96 HP....85 EFI....116 HP
I've been making the same effort with my '88 Toyota
4wd 5speed with 222K miles and I manage between 27.5
and 29.7mpg. This includes some city driving, perhaps
25%, and some hauling, perhaps 15% of the time and up
to ~ 3/4 ton in the back: truck weighs ~3,800
unwashed, rust bucket and lots of tools behind the
seat. Those are also pretty good numbers but, now,
with the Saturn, I hope to use the Toyota only for
what it does best: hauling/mud and snow work.
Best I can do with an '86 Nissan EFI 4x4 is 25 mpg highway...in summer.
If the truck has not been maintained...such as lubed and tuned up...you can gain some there. I'd put a pint of water into the carb (slowly) to decarbon it...flush the oil with a pint of kerosene for 15 mins...advance the ignition some....lube the driveshafts...check the gear oil levels and / or replace....up the tire pressures.
Carry on humans...we are extremely proud of you. ..................
Warning: There are unicorns about...DO NOT throw anything unusual into their enclosure...they might stomp it and also you if you are not quick enough.
22r, atomization, carburetor
carburetor main jet screw and a/f screw spyghost General Efficiency Discussion 5 06-25-2008 01:36 PM
Old School Tango Charlie Introductions 21 06-11-2008 04:07 PM
1st gen crx hf watson EcoModding Central 13 03-17-2008 01:16 PM
