Old 11-27-2010, 11:13 PM   #21 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Cutting a hole in the sheet over the headers is too technically challenging for you? Then don't do it.
Old 11-27-2010, 11:20 PM   #22 (permalink)
99CleanEM1
LOL now lets not make this personal. The mod doesnt apply to me. I have a problem with overheating in the desert not keeping warm. I have used the thermal wraps to keep heat in my exhaust and not heat soak my radiator and intercooler cause we all know hot air is bad for gasoline burning motors longevity and efficiency. Just thought if you expand the idea and cover your exhaust AND motor the heat will be trapped where you want it considerably more then a piece of flammable cardboard.
Old 11-28-2010, 12:11 PM   #23 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.27 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
I've just become aware of the highly technical nature of this mod and regret not including this warning earlier: DO NOT ATTEMPT TO FAB WUNNA THESE UP UNLESS YOU ARE AN ADVANCED MODDER!!! THE CONSEQUENCES OF FAILURE ARE SEVERE!!!
Sjeez Frank
I don't think I'd ever be comfortable with such a contraption under the hood.
It gets pretty hot there, even hotter when something is wrong, like the leaking injector seal I had earlier this year.
The heat made the foam insulation detach from the hard plastic engine cover.
Lifetime fuel consumption :
Old 11-28-2010, 12:16 PM   #24 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Both of them have been under there for about 10 years now, winter and summer.
klean, you knew perfectly well the mod didn't apply to your car as presented (even though it could easily be made to work on your car too) so...
Old 04-21-2011, 11:20 PM   #25 (permalink)
99CleanEM1
10 years with cardboard under the hood ehhh? time for an upgrade
Old 04-21-2011, 11:52 PM   #26 (permalink)
Empty Pocketed Ecomodder
Gen - '05 Liberty Sport
90 day: 22.09 mpg (US)
Blurry - '03 Focus SE
90 day: 35.31 mpg (US)
i'm sure you could combine heat wrap and the cardboard to work, but if you're in the desert i don't see a need for it
Old 04-21-2011, 11:58 PM   #27 (permalink)
ZX - '97 ZX Monaco
OldContinents
90 day: 39.4 mpg (US)
I have had car's original blanket, but it was not enough, I put some Vibroplast M1 there too, after that ice is not melting from hood when I'm driving, also engine noise was slightly reduced.
I have put stuff almost everywhere, to make car more quiet, it is 3 times more effective than same thickness of bitumen and of course a lot lighter.
Forgot to took pic from hood installation, but here is pic from partial installation of trunk:
Of course it is again more added weight that works against fuel economy, I doubt that savings are enough to overcome added weight, but with age I have learned to value quietness in my daily ride.
Mopar to offer Diesel Swap kit for Wranglers Red EcoModding Central 8 08-09-2011 06:23 PM
'89 Civic HF Engine Swap millenniumtree EcoModding Central 12 04-30-2010 12:32 AM
Hood blanket... literally? (engine compartment thermal insulation) Sean T. EcoModding Central 89 11-05-2009 06:31 PM
have some questions about a vx or hx swap soj8888 EcoModding Central 3 07-24-2008 11:54 PM
DIY - Head Swap (Project KDA complete!) SVOboy DIY / How-to 16 01-03-2008 02:17 AM
