Old 01-26-2012, 12:29 PM   #1 (permalink)
Code Blue - '94 F150 XL
The Cherry Bomb - '88 Grand Marquis LS
Hood Latches and Grille Blocks
Question for y'all aero gurus.
I would like to make a grille block for my '94 F150. Preferably, I'd like to just make everything flush from the outside and block out the entire grille as there's plenty of gaps to allow air through...
However, to open my hood I have to reach through the upper grille hole to pop the latch and there's no other way to open the hood. So I'd either have to leave that uncovered or create a removable panel. How have y'all tackled this?
Old 01-26-2012, 12:41 PM   #2 (permalink)
EcoModding Newb
Acura TSX - '06 TSX
90 day: 29.95 mpg (US)
Lafawnda - '01 CBR600 F4i
90 day: 43.18 mpg (US)
Jeep - '02 Liberty Sport
90 day: 18.02 mpg (US)
Nobody who intends to drive their vehicle with gasoline would block out the entire grill, so that is how people have tackled that problem. Your 150 absolutely needs some open grill space because the few gaps you speak of are insufficient.
Based on my reading, it seems most popular to do a lower grill block and leave the upper grill open. I intend to do a lower block myself when I get the time. It's important to monitor engine temperatures when performing these mods.
Old 01-26-2012, 02:12 PM   #3 (permalink)
ooo ooo ooo ah ah ah
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
I left a space around the handle so I could reach it. I also ducted from one grille opening to the trans cooler.
Old 01-26-2012, 02:38 PM   #4 (permalink)
Frank, would you happen to have a picture of your grille block?
Found a picture of your truck with the extended air dam. I may have to browse Lowes to find some edging myself...but I gotta get around to putting the stock air dam back on. You have a sharp ninth gen!
Old 01-26-2012, 02:45 PM   #5 (permalink)
I guess from just browsing the site, looking at all the cars getting full grille blocks, I assumed that I'd just do the same thing. The truck is mostly a winter commuter/miscellaneous hauler for now and regularly sees a 50 mile one-way commute. With only having one grille, I imagine that a 2/3 grille block might be the way to go?
Old 01-26-2012, 02:52 PM   #6 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
Surely you have something more economical to commute with?
Old 01-26-2012, 03:13 PM   #7 (permalink)
I do. Two more economical vehicles actually. I own a 2008 Chevy HHR, but my girlfriend uses that as her daily driver. And a 1988 Mercury Grand Marquis, which I get mid-20 mpgs out of. But the truck is the winter commuter, I'm trying to protect the Marquis from the snow and salt.
I do what I can to hypermile, and have been getting 17-18mpg out of the truck with a full bed cap. Plus, working for the railroad, I drive into work once and work two days. So I only drive ~300 miles my six day work week. I was car pooling with a coworker, but we're on different schedules now. I'm hoping it'll fall back into place again, as that cut the mileage even more.
Old 01-26-2012, 06:21 PM   #8 (permalink)
open duct
On my Dodge,I actually made a nose extension to give some desperately needed corner radii.The grille-block was designed into the nose,and all I do is reach up the open inlet to the hood release.
Old 01-26-2012, 06:38 PM   #9 (permalink)
Blue - '93 Tempo
F150 - '94 F150 XLT
I couldn't detect any aero improvement via better fuel economy with an aero winter front. It almost has to be doing some aero good, but don't think that if you get 18, suddenly you will get 19 or more. The main thing it does is promote fast warm-up and also retains heat far better between commutes.
Old 01-26-2012, 09:40 PM   #10 (permalink)
Big Blue - '06 Dakota Quad SLT
90 day: 20.36 mpg (US)
Miazda - '96 Miata mx-5
90 day: 44.14 mpg (US)
my solution
On my Dakota, the hood latch has to be pulled down. I attached a piece of plastic tubing to the inside of the grille with nylon wire ties. Then attached a piece of semi rigid wire to the latch. I fed the wire thru the tube to the bottom of the grill. Make a small loop in the end of the wire and hang it between the bumper and grille. A pull on the loop does the trick.
