Go Back   EcoModder Forum > AltModding > Saving@Home
Old 09-06-2008, 07:27 PM   #11 (permalink)
vtec-e's Avatar
De Yaris - '04 yaris T2
90 day: 69.55 mpg (US)
Xringer, i hear you. I havent done a thing yet and am running it through in my head to see the pitfalls. The reason i'm not too concerned so far is that the boiler is fed by a fan that would push air up, down, across, whatever. So no matter what heat i take from the chimmney, the airflow would still hopefully be strong. I thought of haing the chimmney in the down position due to the cooling effect on the gas and therefore that would in theory, help the gas flow, if help were needed. Again, i'm open to suggestion.
ollie
Old 09-06-2008, 11:02 PM   #12 (permalink)
Old Retired R&D Dude
Transporter - '09 Escape XLS
ollie
I've got a blower on my oil burner, but having draft pulling hot gas up the flue
is pretty important too. Since if it was all air pressure from a blower at the
bottom, any leaks would be blowing gas out into the living space.
The vacuum effects of the hot flue draws in air, instead of forcing it out.
Here's some stuff about it.
Chimney - Wikipedia, the free encyclopedia
see Chimney draught or draft
I really need that suction effect when I'm burning wood in my boiler..
Without it, every time I opened the upper door to add wood,
the basement would fill up with smoke.
Cheers,
Rich
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 05:04 AM
Larger oil filter for better FE? Gregte DIY / How-to 44 05-23-2010 12:12 AM
Turning off electric hot water heater when not home? ZachUA Saving@Home 33 12-09-2009 10:51 AM
Time for New Hot Water Heater dremd Saving@Home 70 04-17-2009 05:31 PM
Decline in U.S. summer gas use expected for first time in 17 years SVOboy General Efficiency Discussion 13 06-03-2008 10:58 AM
