Old 06-20-2011, 12:17 PM   #1 (permalink)
How about this motor???
I have this motor sitting around and was wondering if it might work for an electric car (which i doubt as it is pretty small) or maybe for an electric motor cycle?
Old 06-20-2011, 12:34 PM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
The only issue with that motor is its designed for high voltage. That means you'd need a high voltage pack as well as an AC motor controller. Also, the rating of 2.8 kW isn't real high. It might be enough for a motorcycle, but packing in that many batteries into a motorcycle would be a real trick.
Old 06-20-2011, 04:29 PM   #3 (permalink)
Ryland's Avatar
honda cb125 - '74 CB 125 S1
90 day: 79.71 mpg (US)
green wedge - '81 Commuti-Car
Blue VX - '93 Civic VX
It might be nice for an electric bicycle if you could find a way to string together a whole pile of small batteries, ones like you use for model airplanes might work well, but good luck finding a speed controller for it.
