Mine's really accurate, except at the higher numbers it only moves in increments of 0.3. Still, as I'm going through a tank I watch the UG marching along in 0.1s and the car marching right along with it using larger steps.
My last tank was a celebration of calibration. The UG matched the pump with 14.762 gallons and almost matched the car's 424.4 miles with its 424.62 miles. The car was within 0.3 of the UG and I'm happy with that. A few tenths of a reported MPG isn't going to make me drive past a gas station when I'm almost empty. But my triputer says I should be able to go another 20 miles!
At last fill-up, number 30 by POE (active)
47) "Drive without brakes" (DWB) Minimize use of the brake pedal. Each time you press it, you're effectively converting gasoline into brake dust and heat.
