Go Back   EcoModder Forum > AltModding > Saving@Home
Old 06-22-2009, 08:55 PM   #1 (permalink)
How to affix radiant barrier to metal garage door
I have a metal garage door facing the afternoon sun, and my garage is situated directly under a part of the upstairs living quarters (master bedroom, specifically) - the inside of the garage door is unbearable to touch during the afternoon.
So I bought a roll of that radiant barrier stuff, basically it's bubble wrap with a layer of mylar on either side of it.
Now... how do I stick it to my garage door? I was thinking 3M 90 but that stuff is only adhesive up to about 140F and then wants to get sloppy.
Any other ideas? HVAC tape?
Old 06-23-2009, 11:25 AM   #2 (permalink)
YJ - '89 Wrangler
FOCUS - '00 Focus ZTS
The Wife's Hot Rod - '09 G8 GT
Last 3: 23.22 mpg (US)
Sheet metal screws with big plastic washers.
Old 06-23-2009, 11:57 AM   #3 (permalink)
Bandit 600 - '96 Bandit 600
90 day: 36.69 mpg (US)
Ranger 3L - '99 Ranger XLT
I have a garage door that faces the same direction. I slid rigid insulation into the back and then fastened it in place with foil tape. The foil tape stuck to the metal but eventually failed to hold on the foam. I think you might have the same problem with the foil tape. It may be worth a try anyway. What about high temp silicone adhesive?
