Old 09-07-2010, 06:36 AM   #1 (permalink)
How is the battery of a hybrid car charged?
hyrid car runs on electric power at low speeds, where from the battery giving this power is charged?
Old 09-07-2010, 06:40 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Hybrid cars mostly run on the gas engine, even at low speeds. If you are running on electric, the power still comes from the engine in the form of using the motors as generators.
Old 09-07-2010, 01:06 PM   #3 (permalink)
Originally Posted by villiom View Post
hyrid car runs on electric power at low speeds...
That isn't necessarily the case. Some CAN run on electric only, but generally the electric motor assists the engine when the car accelerates. It takes much more power to do that than to drive at a steady speed, so a hybrid can have a smaller engine that is more economical to run at cruising speed. Normal cars have to have oversized engines to give power to accelerate, so they are inefficient at cruising speed. (This is something called Base Specific Fuel Consumption, or BSFC, which you can look up.)
The power for the hybrid mostly comes from braking: the electric motor acts as a generator, putting power back into the batteries. In addition, if the battery drops too low, the engine will recharge it.
See for instance here for more info: HowStuffWorks "How Hybrid Cars Work"
Electric car conversion: Project ForkenSwift MetroMPG Fossil Fuel Free 980 04-25-2012 10:12 AM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Win $100.00 in Free Gas! Design Contest: Ecomod my Ride XFi EcoModding Central 127 02-17-2011 12:07 AM
VW 2013? We shall see! DIMS EcoModder Blog Discussion 11 09-27-2009 10:35 PM
Toyota 'Hybrid X' concept car NeilBlanchard EcoModder Blog Discussion 0 08-25-2008 08:56 PM
