Old 01-21-2010, 04:12 PM   #1 (permalink)
How to belt drive just about anything from any engine - DIY
This article describes how to belt drive just about any device like a welder, pump, second alternator, or whatever else you need to spin from the front of most any engine.
It covers a bush method of mounting a second drive pulley to the front of the engine and more professional methods also.
The article also has a simple methods of finding bolt hole centers (where to drill the holes) from tight locations without measuring. Much of the information comes after building over a 100 PTO mounts mostly in the field.
The article was originally written for boats, where we have to do this all the time, but it will work with just about any off the grid or survival situation or remote radio spot where lots of extra DC amps are needed.
The link is-
Second marine alternator
Hope this helps
Scott
The Following User Says Thank You to yachtwork For This Useful Post:
Peter7307 (02-12-2010)
Old 02-08-2010, 03:10 PM   #2 (permalink)
Hey Scott, that's a pretty interesting read. Doesn't look like many of the ecomodders are too interested in this, but you can bet the car stereo boys will love it.
Old 02-09-2010, 09:12 PM   #3 (permalink)
There might be other uses too:
Auto DC Arc Welder Plans
Old 02-12-2010, 12:15 AM   #4 (permalink)
Hey Scott,
A great article and very helpful too.
Thanks for the post.
Cheers , Pete.
DIY hybrid (detailed noodling of crankshaft-mated electric assist method) NiHaoMike Hybrids 16 03-03-2012 05:41 PM
Article: Lean burn on an otherwise stock engine (testing Acura RSX K-Series engine) tjts1 EcoModding Central 4 01-07-2010 01:22 PM
Belt squeal, engine on and off (Pulse & Glide) AnDoireman Hypermiling / EcoDriver's Ed 26 06-17-2008 11:33 AM
DIY decel fuel cutoff; alternator regulation; auto start/stop MetroMPG EcoModding Central 0 11-29-2007 02:04 PM
Basic EcoDriving Techniques and Instrumentation SVOboy Instrumentation 2 11-17-2007 11:38 AM
