Old 03-17-2013, 03:36 AM   #1 (permalink)
Buddy - '94 Acura Integra GSR
90 day: 29.89 mpg (US)
Lightbulb How to calculate MPG during a partial fill
I was running on E and was starting to get nervous about driving so I put in two gallons of gas instead of filling up. Now, how do I calculate my MPG after I fill up? Thanks!
- Aaron
How-To: When you do a partial-fill (meaning you didn't fill the tank, e.g. you only put in a few gallons) keep the odometer running and when you finally do fill up, add the gallons from the partial-fill to the full tank. If you put in two gallons then later fill with 10, add those two gallons to the fill-up to get a total of 12 and use that in your MPG calculator.
Old 03-17-2013, 05:31 AM   #2 (permalink)
Eco-ventor
jakobnev's Avatar
Princess - '92 Mazda MX-3 GS
House of Tudor
Team Mazda
90 day: 53.54 mpg (US)
Shirubāarō (*´ω`*) - '05 Toyota Prius Executive
90 day: 54.88 mpg (US)
Blue Thunder - '20 Hyundai IONIQ Trend PHEV
Plug-in Hybrids
90 day: 587.16 mpg (US)
Send a message via MSN to jakobnev
Just add the two gallons to whatever you put in later to fill the tank. (??)
Old 03-17-2013, 08:18 AM   #3 (permalink)
The Dirty330 Modder
Gealii's Avatar
CruzeRS - '15 Chevy Cruze LT RS
90 day: 41.29 mpg (US)
dont reset your trip and make note of how many gal you added than add the gal to youro fill up
"The only real mistake is the one from which we learn nothing."
- Henry Ford
Old 03-17-2013, 03:11 PM   #4 (permalink)
But wouldn't that assume that I used two gallons by the time I fill-up? I was thinking more of finding out how much gas each mile uses and using that in some sort of equation?
Old 03-17-2013, 03:46 PM   #5 (permalink)
It all works out, just add your part fill to next full fill, even if 5 of them, you'll get a high tank, but average mpg will work out, kind of like 3 tank MPG. You could put in th 2 gallons and tip OD and reset trip and it would all average out, but give crazy high tank MPG.
Old 03-17-2013, 06:17 PM   #6 (permalink)
mcrews's Avatar
The Q Sold - '02 Infiniti Q45 Sport
90 day: 23.08 mpg (US)
blackie - '14 nissan altima sv
get a scangaugeII.
MetroMPG: "Get the MPG gauge - it turns driving into a fuel & money saving game."
ECO MODS PERFORMED:
First: ScangaugeII
http://ecomodder.com/forum/showthrea...eii-23306.html
Second: Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Third: Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
Fourth: rear skirts and 30.4mpg on trip!
http://ecomodder.com/forum/showthrea...tml#post247938
Old 03-18-2013, 04:00 PM   #7 (permalink)
euromodder's Avatar
The SCUD - '15 Fiat Scudo L2
NO.
What you already used up, you'll need to add again when topping up.
What's left in the tank, you won't need to add again
Keep the miles counter running until you fill up completely, and add the previous 2 gal to the volume you tanked - done.
Old 03-19-2013, 02:23 PM   #8 (permalink)
Alright, it's starting to click in my head. So just to be clear, if the next time I fill up I pump 10 gallons, I want to add the previous two gallons to that correct? I'll have a total of 12 gallons that I will use to determine MPG for that tank right? I use the total OD mileage. Thanks!
Old 03-19-2013, 02:32 PM   #9 (permalink)
The Dirty330 Modder
Gealii's Avatar
yes just make sure you dont reset your trip untill you fill completely
- Henry Ford
Old 03-19-2013, 02:41 PM   #10 (permalink)
Excellent, thanks!
