Old 02-06-2012, 11:21 AM   #1 (permalink)
How can you prevent a smooth underbody tray from getting exhaust fumes inside?
Making a smooth underbody looks easy.
How can you prevent exhaust fumes from getting inside the cabin?
Maybe you should leave an open space at the rear?
Or maybe some vents?
Old 02-06-2012, 11:29 AM   #2 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
Just make sure the end of the exhaust pipe sticks out of the bellypan I would think would be enough.
Old 02-06-2012, 12:37 PM   #3 (permalink)
Aero Wannabe
COcyclist's Avatar
TDi - '04 Golf
90 day: 51.68 mpg (US)
That is all I did and I have had no problems with fumes. As long as your exhaust and floor aren't both rusted through you should be fine. Some folks with hotter exhausts than mine (gasoline fueled) leave out a channel of coroplast close to the pipe so the plastic doesn't melt.
60 mpg hwy highest, 50+mpg lifetime
TDi=fast frugal fun
Old 02-06-2012, 12:57 PM   #4 (permalink)
'10 Kia Forte EX 2.0 - '010 Forte EX
90 day: 37.25 mpg (US)
Unless there's a leak in the exhaust system, it shouldn't be a problem as long as the tailpipe isn't covered up.
Old 02-06-2012, 05:10 PM   #5 (permalink)
mcrews's Avatar
The Q - '02 Q45 Sport
90 day: 23.08 mpg (US)
1. Have you looked at any of the smooth under belly panels posted on this forum?
2. Every car sold in america has to have exhaust tips that send the exhaust past the car.
Given those two statements I cant really understand your question.
Here is an example of a rear panel ( on my car.....see links in mt signature)
ECO MODS PERFORMED:
First, Grille Block
http://ecomodder.com/forum/showthrea...e-10912-2.html
Second, Full underbelly pan
http://ecomodder.com/forum/showthrea...q45-11402.html
third, rear skirts and 30.4mpg on trip! http://ecomodder.com/forum/showthrea...tml#post247938
Old 02-06-2012, 09:55 PM   #6 (permalink)
Schwinning!
Sven7's Avatar
The Anal Probe - '92 Probe GL
Team Ford
90 day: 35.92 mpg (US)
Don't worry about it.
Originally Posted by Weather Spotter View Post
Nothing fell off so that is good.
