Old 04-08-2009, 01:18 AM   #1 (permalink)
How come my MAP is higher? What controls it?
I went to get my car serviced since it's been a long time since that happened and they drained ALL the fluids and replaced them. The idle stayed the same ( think they adjusted it too) but the MAP is now higher. Before it was 3.9 while idling and now it's 4.1 (this is on the scangauge 2)
I thought that the lower it is the better, or am I missing something? I also had my valves adjusted, does it have anything to do with it?
Old 04-08-2009, 07:37 AM   #2 (permalink)
dcb
needs more cowbell
dcb's Avatar
pimp mobile - '81 gs 250 t
90 day: 96.29 mpg (US)
schnitzel - '01 Golf TDI
90 day: 53.56 mpg (US)
A clean air filter can make a difference in map. Engine needs a certain amount of o2, and there will be a bigger pressure drop over a dirty filter.
I assume hydraulic lifters so not sure what they would adjust on your valves though.
Reading a MAP sensor dcb Instrumentation 10 09-19-2010 10:50 PM
can you use a DC motor controller to charge car battery from a higher voltage battery modmonster EcoModding Central 9 02-13-2009 08:14 PM
MAp sensor to 5v power momentary switching Dust Off-Topic Tech 0 10-10-2008 04:41 AM
VX at higher speeds siray13 EcoModding Central 5 07-28-2008 02:31 PM
Johnson Controls Batteries bennelson Fossil Fuel Free 1 03-14-2008 12:28 AM
