Old 07-23-2008, 11:26 AM   #31 (permalink)
CobraBall's Avatar
Great looking Black Deuce Coupe.
I'm curious, why a "deuce coupe" which is usually associated with the 1932 Ford Coupe and the Beach Boys. http://static.howstuffworks.com/gif/...-hot-rod-2.jpg
Old 07-23-2008, 02:44 PM   #32 (permalink)
Altima SE - '07 Altima 3.5 SE
90 day: 25.56 mpg (US)
RSX-S - '02 RSX Type S
90 day: 27.24 mpg (US)
Send a message via AIM to 99clipsgst
I know that I have a good size spoiler but it's OEM. Since the eclipse already has a low drag coeffecent would this spoiler be better on or off?
Old 07-23-2008, 04:27 PM   #33 (permalink)
It's too tall for drag reduction,and it's chord is too short for any appreciable downforce(which you wouldn't need anyway).I'd say its just for styling purposes.It probably generates a little drag,so removing is okay,however,drag may be so low,its a wash.It's your call.
Old 07-23-2008, 04:55 PM   #34 (permalink)
CobraBall's Avatar
BlackDeuceCoupe
Love the 5 window coupe w/ the Olds thru the valve cover spark plug wires.
Best friend has a 34 Plymouth 4dr. PE with a '57 Dodge Hemi.
I've got a '33 Ford chopped full fendered Tudor w/ 350/350.
At $3.90/gal it is once a month driver.
Old 07-23-2008, 05:00 PM   #35 (permalink)
CobraBall's Avatar
99clipsgst
You might tuft test w/ and w/out the spoiler. Have someone photo the tests. I would place the tufts on the back of the rear decklid. I suspect the test will show no effect on the tufts providing you aren't running flat out.
Old 07-23-2008, 06:20 PM   #36 (permalink)
CobraBall's Avatar
Black Deuce Coupe,
Maybe a 32 Hiboy with a turbo 4 banger, 5 speed. Probably 2200-2300 lbs. HP dependent on boost.
Have you been to the Bonneville Nationals in August?
CB
Old 07-23-2008, 07:02 PM   #37 (permalink)
CobraBall's Avatar
The Bonneville Nationals is a PhD in streamlining.
Seeing the Nebulus Theorem, Turbinator, or Al Teague has been awe-inspiring. Burland at 422 with 50% power . If you ever go, take Plenty of WATER and SUNSCREEN (cover everything exposed and not exposed). The guys/gals in the pits are very friendly and approachable. The pits are so big that a bike would help.
Old 10-23-2008, 03:21 AM   #38 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 59.38 mpg (US)
What about spoilers for hatchbacks? I've noticed a few types:
- Type 1 - placed below the rear window
- Type 2 - above the window, extending above the roofline with a gap under it
- Type 3 - above the window, extending the roof horizontally of slightly down
- Type 4 - above the window, tiny
Here is a Honda with two spoilers, types 1 and 3
Which of these will help or hurt FE? I can tell that type 2 probably produces drag, but what about type 1? Does the tiny type 4 do anything?
Piwoslaw's Peugeot 307sw modding thread
Old 10-23-2008, 07:58 AM   #39 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
1 will do nothing for aero, its just added weight.
2 will add drag
3 will help a very small amount IF it slopes down slightly
4 will make no noticable difference
Old 10-23-2008, 10:18 AM   #40 (permalink)
Blackfly - '98 Metro
90 day: 67.07 mpg (US)
ForkenSwift - '92 Metro EV
90 day: 107.11 mpg (US)
U.F.O. - '00 Insight
90 day: 83.36 mpg (US)
I agree with Tim's reply.
focus1.6uk (01-13-2011)
LinkBacks (?)
LinkBack to this Thread: http://ecomodder.com/forum/showthread.php/how-decide-whether-remove-rear-spoiler-decrease-drag-598.html
Posted By For Type Date
Keversite.NL • Bekijk onderwerp - Dakspoiler This thread Refback 05-20-2010 02:36 PM
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 11:19 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 03:09 PM
