Old 05-13-2009, 09:27 PM   #71 (permalink)
bonneville
Originally Posted by tripp323 View Post
Ok. You say " the lift can not be enough to offset the added drag, by definition" and you are the expert. But then how does a plane take off? Obviously you can generate enought lift using a wing at higher speeds. Your point about loss of traction is well taken. But put that aside for a sec - say we are on the Bonneville Salt flats and I want to lighten my prototype high-mileage vehicle - at some speed couldn't we use lift like a plane about to take off? I may have trouble controlling this - but if I control lift so that I still have enough traction to keep moving forward? Sorry to challenge your paradigm - hope you will keep an open mind for this curious newbie question.
At Bonneville,weight is your friend.If you lose traction at speed and go sideways,there is a very good chance you'll be airborne.If you land on your side and barrel-roll,that will be the last drive you'll ever take.The centrifugal forces will tear your organs loose and they'll end up in your feet and mouth.It's a horrible way to go! If your fortunate,you'll get your parachutes out in time to keep you straight down course 'til you grind to a halt.--- Forget about rolling resistance reduction by unloading them with a lift device.We don't want to see you at the morgue.--- Get the best LRR tires you can find and live with them.Emphasis on "live."
Old 05-13-2009, 10:32 PM   #72 (permalink)
Originally Posted by brucepick View Post
<snip>
Of course it takes energy to lift part of the car's weight off the ground, which ultimately comes from your engine and your fuel. From what I've read here before, that penalty occurs as drag. All other things being equal, a car with more lift will have a higher drag coefficient. Nuttin' comes from nuttin', and NSTAAFL: no such thing as a free lunch.
EXACTLY!!!!
And what you said about mass and stuff is bang on, i'm a physics type guy, i haven't pursed it yet in post sec, but loved it in high school, and flying and aerodynamics are another love of mine, so when i kinda read some of this i kinda have a hard time seeing how somebody thinks this will work.
The best way to increase efficiency through aerodynamics in the sense of lift vs downforce, is to remain as neutral as possible.
In flying there are 2 types of drag, induced drag, (created by the production of lift) and parasite (created by things that don't produce lift)
You can trim little bits here and there from induced by creating winglets and such. But really not that much, and you'll certainly get almost no gains fiddling with it on you're car, so you're best off to eliminate as much as possible by making things lift/downforce neutral.
Parasite drag is really what you should focus on, and is what may be eliminated by having a wing that isn't for downforce, but for guiding air, just like the ones shown in some of the earlier posts.
So the way i see it is, rip off wings that are obviously used for downforce and just leave the ones that look like the may be used to guide air.
Lets start it off
This is my car
And there is a MASSIVE upturn so it's just adding downforce and drag.
Oh and i just did a quick calculation of fuel mileage last week, and with that wing, and thrashing it, and driving quick and doing all the wrong things, still managed to get roughly 35 mph. And it's an automatic.
Old 06-07-2009, 08:21 PM   #73 (permalink)
Hey Daox! I remember you from Tercel Online. To see what the air's doing on your rear window, cut a bunch of pieces of yarn about 2" long. Then tape them all over the window. The "tails" will act like little mini windsocks to show you the direction of the air flow. Sport Compact Car magazine did that on a notch-back 240sx. The article was to show how vortex generators decrease the size of the low pressure zone behind the rear window. They used AirTab vg's.
As far as I know, the optimal length to width/height ratio is 7:1. Therefore whatever you can do to lengthen the rear deck (or roof on a hatchback) may very likely lower the drag coefficient.
Old 06-13-2009, 12:22 PM   #74 (permalink)
is not covered in bees.
Istas's Avatar
Car - '92 Legacy L (automatic)
90 day: 32.49 mpg (US)
Send a message via AIM to Istas
Actually, ebouwman, I think that wing on your car might be doing some good. It's hard to tell without a profile pic, and the only reliable way to know is by experimentation, but if that wing is catching the stream of air coming off the roof of the car, it will be helping to separate it cleanly from the car, rather than dragging it into the car's wake. It's less than the 30-degree angle aerohead quoted. I'd try some A-B-A-B testing, if you can, before conclusively claiming one way or the other.
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 52 07-20-2009 11:26 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 10 07-03-2008 04:00 PM
Powered by vBulletin® Version 3.8.4
Copyright ©2000 - 2009, Jelsoft Enterprises Ltd.
Content Relevant URLs by vBSEO 3.3.2
