Old 01-11-2010, 08:14 AM   #81 (permalink)
recession proof rebel
k.civic.f4i's Avatar
looks like purely downforce to me
how to.....
http://ecomodder.com/forum/showthrea...cks-11998.html
http://ecomodder.com/forum/showthrea...how-12301.html
true wealth comes from good health and wise ways
Old 04-18-2011, 11:01 PM   #82 (permalink)
Spud - '94 Aspire SE
Team Ford
90 day: 40.32 mpg (US)
Hi all, I'm trying to decide if my spoiler is doing anything at all to help my mileage.
carphotos.cardomain .com/ride_images/4/400/2161/38498580001_large.jpg
(copy and paste without the space to view link)
This is similar to what my car looks like. The spoiler has a slight upward lip if you look close, but I am unable to determine whether it was designed with FE in mind or teenagers in mind, haha!
Any thoughtful help is appreciated!
Old 04-18-2011, 11:44 PM   #83 (permalink)
That looks like it helps.
Old 04-19-2011, 11:49 AM   #84 (permalink)
Thumbs up
Speed_Bump:
The Capri's rear end is made such that air has a hard time separating from the vehicle without creating a lot of turbulance. My opinion is that your spoiler is probably helping air separate more cleanly.
Another thing that I might recommend looking into is whether or not your bumper is acting like a scoop, trapping air under the car. If you can find a way to help air get out from under the car better, it would speed up the air flow under the car as well as help fill in the low pressure area directly behind the car.
Old 04-19-2011, 08:08 PM   #85 (permalink)
Team Ford
Thanks Daedalus and Winkos, I think that I will just leave that part of my car alone.
I need a replacement front fascia as the lower part of my air dam has been broken. Maybe while replacing the fascia I can add a partial grill block and underbelly pan. These are projects for different threads though.
Old 04-21-2011, 04:07 AM   #86 (permalink)
Leviticus - '97 Sebring Convertible JX
90 day: 21.33 mpg (US)
Fiesta - '012 Fiesta SE
90 day: 30.53 mpg (US)
Ok, so from what I got from all this is this:
A spoiler that points up in the back increases drag, therefore decreasing the aerodynamicness of the car, but keeps it on the ground better which is only good at reeeally high speeds.
A spoiler that is flat or slightly pointed down is good, helping the air flow over the car and decreases drag.
My car's trunk curves down a lot at the end, so as long as its not over like what 12/13 degrees it helps, right?
Old 04-21-2011, 02:36 PM   #87 (permalink)
BamZipPow's Avatar
BZP T-100 (2010) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.99 mpg (US)
BZP T-100 (2011) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 20.93 mpg (US)
BZP T-100 (2009) - '98 T-100 ext cab - 3.4L/auto SR5
Last 3: 19.01 mpg (US)
BZP T-100 (current) (2012) - '98 T-100 ext cab - 3.4L/auto SR5
90 day: 19.56 mpg (US)
Send a message via ICQ to BamZipPow Send a message via AIM to BamZipPow Send a message via MSN to BamZipPow Send a message via Yahoo to BamZipPow
Make 4 more posts then...
Old 04-21-2011, 06:57 PM   #88 (permalink)
I got a spoiler that curves a bit at the top for really cheap, ill just sell that and get one that's flat.
Old 06-30-2011, 09:17 AM   #89 (permalink)
aero guerrilla
Piwoslaw's Avatar
Svietlana - '05 307 SW
Diesel
90 day: 55.98 mpg (US)
I've noticed a lot of Toyota Yarises (Yarii? Yarum? Yarisitachi? "Yaris Yaris"? It's like Indonesian; you double up the noun to pluralize it.) with a spoiler on the rear hatch. Not the typical way-up-there-and-ravage-the-airflow spoiler, but more like a roof extension:
They give the rear a small Kamm effect:
I've seen so many of them in Europe that I'm starting to think they are OEM, yet not all Yarises (Yarii? etc....) have them.
Piwoslaw's Peugeot 307sw modding thread
Old 06-30-2011, 12:17 PM   #90 (permalink)
euromodder's Avatar
Hägar - '05 V50 1.6L Diesel
Diesel
90 day: 52.05 mpg (US)
Snert - '06 S40 1.6L Diesel
90 day: 58.06 mpg (US)
IIRC, they were a Toyota option.
Rear spoilers weren't standard on most Yaris.
Lifetime fuel consumption :
EcoModding for Beginners: Getting great gas mileage. SVOboy EcoModding Central 54 05-08-2011 10:19 PM
Sources of Aerodynamic Drag in Automobiles and Possible Solutions SVOboy Aerodynamics 12 02-17-2010 02:09 PM
