Old 12-10-2010, 05:55 PM   #11 (permalink)
Left Lane Ecodriver
RobertSmalls's Avatar
Zombie Insight - '00 Insight MT
90 day: 62.82 mpg (US)
The big + lug on the battery is on the wrong side of the contactor relay, which means it's not live unless the key is in the on position and the ECU says it's okay. Use the other side of the relay, and be careful with the high voltage. Understand how the big switch on the top of the battery works, and leave it at "OFF" except when the battery in a safe location, e.g. installed in the car with its cover on. The switch must be "ON" to run the grid charger.
The KaW was just there to record the efficiency of the charger: 84%.
Old 12-13-2010, 04:49 PM   #12 (permalink)
Thanks Robert, I got the charger built. I'm just waiting on my lineman gloves to arrive before I start poking around on the battery. Mike had me call him. He has been a great help also, but Mike is way more intelligent with electronics and electricity than I am. He said I might have to switch on one power supply at a time if the battery is too discharged. I am not sure how I will know. I think he said if the voltage doesn't start going up when the charger is plugged in, then I need to do one at a time.
Old 08-22-2011, 08:03 PM   #13 (permalink)
Hi sdnomad
i need replace my IMA Battery in my civic 07. Did you be able to DYI your car? Do you have a Diagram and the complete part list that you use ?
i need make a grid charger?
i will apreciate your help.
Thanks
Old 09-13-2011, 07:33 PM   #14 (permalink)
HI sdnomad
did you fix your IMA Battery ?
Civic Hybrid MPG class action lawsuit settled... now heading to small claims court MetroMPG Hybrids 74 05-09-2012 08:34 PM
DIY Solutions to Honda Hybrid Battery Problems (Insight, Civic, IMA) RobertSmalls Hybrids 90 04-01-2012 06:11 PM
Driving a Civic Hybrid alohaspirit General Efficiency Discussion 26 01-02-2011 08:32 PM
Any info on 1st gen civic hybrid wheels? weight, value. Ryland EcoModding Central 1 04-11-2010 08:44 PM
Should I buy this civic Hybrid? jasonck08 General Efficiency Discussion 5 11-03-2009 06:33 PM
