Old 09-08-2009, 06:26 PM   #1 (permalink)
Silver Turtle - '02 Focus Zx3
90 day: 38.83 mpg (US)
Question --- How do $19.99 oil change places do it?! ---
Ok, so If I go to autozone, pepboys, etc. I can get the diy oil change (5qts and an oil filter) for about $15 (plus tax).
So how do all these $20-25 oil changes do it? They have to pay for labor (probably 20mins for one oil change), and the location every month, and insurance, etc etc etc.... ?
How much could they possibly get a wholesale price of oil and filters for?!?
Old 09-08-2009, 06:28 PM   #2 (permalink)
McTimson's Avatar
The Turkel - '93 Tercel
90 day: 40.39 mpg (US)
Felix - '09 Yaris
90 day: 34.49 mpg (US)
Probably by overcharging for the other stuff they do, like suspension stuff, tires, and minor tuneups. The $20 oil change gets you in the door, and then they point out other things that might need work, and suck the money out of you.
Old 09-08-2009, 06:33 PM   #3 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
Tim already mentioned the low-price leader thing, but they also buy crappy oil in 500 gallon barrels, which I'm sure makes the oil a lot cheaper
Old 09-08-2009, 08:29 PM   #4 (permalink)
oldscoob - '87 wagon gl/dr
90 day: 47.06 mpg (US)
if the oil is in large drum it is cheap. the filters could be a set standard before name brand slapped on (its a sick world, I worked at quick lube 15 years ago). it could be a fram, it could be alot of things...
a tip to you: demand bottles, bring your own filter.My ol sube needs the tough guard with bypass screened (I gain a full open pressure relief at 65psi every morning) .
Else, it really is simple, not much to worry over.
I serviced almost 2000 last I knew. Not many need a special filter. In fact the EA sube engines is the highest (and only) real life pressure that needs to kick open relief to avoid hurting itself with 100+psi (aviation standard)
Old 09-08-2009, 10:34 PM   #5 (permalink)
Hi-Tech Redneck
Johnny Mullet's Avatar
Christine - '98 Metro Base
90 day: 62.59 mpg (US)
Send a message via AIM to Johnny Mullet Send a message via MSN to Johnny Mullet
Buying in bulk makes it all cheaper. If you buy cheap stuff in bulk, then you got a lot of crap to get rid of.
Old 09-08-2009, 11:21 PM   #6 (permalink)
...beats walking...
Old Tele man's Avatar
Vibe - '09 Vibe Base (2ZR-FE)
90 day: 32.19 mpg (US)
Goldie Locks - '011 Cruze LTZ
90 day: 29.42 mpg (US)
...most new cars use 5W-20 oil, but the oil guys typically only stock 10W-30, etc., and make you pay MUCHO-MUCHO for the correct weight oil...then, throw in the "disposal" fees and you're closer to $50-$60 or more, with synthetic (Mobil 1, Kendall, etc.) even higher.
2011 Chevrolet Cruze LTZ 1.4LT 6A
2009 Pontiac Vibe 1.8L/SFI 4A
2004 Pontiac Vibe 1.8L/MFI 4A
2003 Ford Focus ZX5 2.0L/Zetec 4A
1971 Dodge Charger 318 3A
1970½ Plymouth AAR 'Cuda 340/6BBL 4M
1968 Dodge Charger 383 3A
1967 Plymouth Barracuda Formula S 383 4M
1965 Plymouth Barracuda Formula S 273 4M
Old 09-08-2009, 11:27 PM   #7 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Wholesale filters are only a couple bucks each, and oil is around $1+/quart, so they can at least break even. The biggest thing is being able to point out other problems, and get money from other work, as was mentioned.
Old 09-08-2009, 11:30 PM   #8 (permalink)
...beats walking...
...in the merchandising business, it's called a "...LOSS LEADER..." A low (or under) priced item that "...gets foot traffic through the door..." and thus potential "...add-on..." sales.
Old 09-09-2009, 01:32 PM   #9 (permalink)
wagonman76's Avatar
Red Car - '89 Celebrity CL 4 door
Team Chevy
90 day: 36.47 mpg (US)
Winter Wagon - '89 6000 LE Wagon
90 day: 28.26 mpg (US)
Buying in bulk. And being a business they can buy for a heck of a lot less than we would be able to buy the stuff for, even in bulk. And being a big chain like most of them are, their quantities are bigger since they can use the buying power of the entire company, hence a bigger quantity discount.
And by all the other services they constantly push on you, with the fact that many people go for it.
Winter daily driver, parked most days right now
Summer daily driver
Old 09-09-2009, 05:16 PM   #10 (permalink)
home of the odd vehicles
rmay635703's Avatar
Silver - '010 Cobalt XFE
You do know you can buy cheap detergent gasoline rated dino oil for $.69-$.89 cents a quart in a normal store most any day of the week? I don't use the stuff instead paying mucho grande for synthetic but it is available at places like fleet farm.
Lets be generous $5 or less for oil and filters can be had very cheap as well if you buy multiples. So yes they can make money on the 10 minute oil change.
Effect of gear oil viscosity on transmission efficiency (Metro owners take note) MetroMPG EcoModding Central 36 06-11-2011 04:04 AM
Oil change recommendations? rjacob EcoModding Central 48 08-02-2010 05:04 PM
Oil change guys under-inflated my tires Formula413 The Lounge 26 06-20-2010 08:46 PM
Restore oil additive... suspectnumber961 The Unicorn Corral 43 05-14-2010 03:40 PM
