09-13-2009, 09:05 PM
#11 (permalink)
Moderate your Moderation.
Originally Posted by Christopher Jordan
Just my opinion- those old design diamond frame trikes are unsafe disasters at all speeds. I had an old Huffy in the mid 1970s and at 2 mph it threw me off hitting a driveway and I fell a long way then rolled into a busy street.
Undaunted; the next day it wouldn't stay on the ground around a corner- tipped, went over- bloodied up badly. That was at 5 mph. Granted- about 10 to 20 pounds of battery would have helped, it would not help my grip or balance problem. Bye bye diamond frame trike.
My solution was to be low, but that is not for everybody. I have a hub motorised trike and an EV microcar 3-wheeler- both are a little bit faster than 10 mph (legally in CA.: 20/50 mph) I would never EVER try that on a diamond frame trike!
Adding rake to the front forks helps with stability on delta trikes. If you check out the street legal "Tri-Sport" trikes, they have a decent rake and a low stance. I've never seen one 2-wheel before, unless forced to do so. Under "normal" driving conditions, they're fairly stable.
I'd like to think that people might open their eyes at some point... instead, I find it more and more likely that I'll just close mine.
-- Author kept secret.
Je ne veux pas d'une meilleure vie. Je veux être heureux avec celle que j'ai maintenant.
(I do not want a better life. I want to be happy with the one I have now.)
09-14-2009, 02:22 AM
#12 (permalink)
Ecomod noob
ZJ - '95 Grand Cherokee Laredo Upcountry 90 day: 20.57 mpg (US) Neon - '03 Neon SE 90 day: 36.28 mpg (US) S'Crew - '02 F150 Supercrew XLT 90 day: 16.4 mpg (US) EX - '94 Explorer 90 day: 19.58 mpg (US) Ranger - '90 Ranger Last 3: 28.02 mpg (US)
Originally Posted by MadisonMPG
In all honesty, should she be riding a bicycle? With that health rep sheet I would be afraid to get out of the house.
Try telling her that!! I'll stand back for the blood bath. Seriously, the last thing she wants is to give up, or slow down anymore than she already has.
When it comes to Heroes, RENEGADES are mine!
09-14-2009, 02:25 AM
#13 (permalink)
If she's determined to keep going, let her keep going, I say... there is a limit, though, where she's not going to do any good for herself... you, as her mate, have to watch for that.
09-14-2009, 02:32 AM
#14 (permalink)
Ecomod noob
I am well over the trikes weight limit, it flexes a lot more than I would like it to when I sit on it. My son and daughter (21 and 19) enjoy riding it, though my son prefers to ride it with the non-driven wheel in the air (I'll see if I can a pic when he is home this weekend). The upside to the two wheel antics showed my wife that the trike isn't as stable as she expected.
She has ridden a recumbent trike, but that aggravated her hip.
Please understand that I'm just looking for ways to keep her active despite her ailments and frailties. We're only 4 days into using crutches and I think she is ready to wrap one around my neck... Mainly because I refuse to pull her wheelchair back out (she needed that two years ago...).
To that end, here is the rear drive on the trike, I have room to add another "hub" on the axle for a regular freewheel...
09-14-2009, 02:37 AM
#15 (permalink)
Ecomod noob
Oh yeah, I'm watching. Been looking after her for 26 years, but the medical issues have been with us for about 15... Now I have to be careful that I don't sacrifice my own issues. I just had a second gel injection (of three) in my left knee. I'm a candidate for replacement. Yippee, huh? Falling apart too young I tell ya...
09-14-2009, 10:35 AM
#16 (permalink)
The design looks almost perfect for a HSD retrofit (replace transmission with PSD/MG1 and add MG2) but it won't offer much in your application considering it will run in EV mode most of the time.
An IMA setup, however, is very easy. Add another gear on the drive shaft and mount the motor to the frame. Use sheet metal to make a bracket for the motor.
If America manages to eliminate obesity, we would save as much fuel as if every American were to stop driving for three days every year. To be slender like Tiffany Yep is to be a real hypermiler...
Allie Moore and I have a combined carbon footprint much smaller than that of one average American...
09-14-2009, 01:01 PM
#17 (permalink)
zjrog, how much do you way? If you are exceeding the weight limit of the bike you a probably a rather large man. I would try to lose weight, that will help tons of health factors.
09-14-2009, 02:21 PM
#18 (permalink)
I can sure understand that! Being stubborn helped me!
That trike is probably independent (one wheel) rear drive. Some had differentials, but not many. If a motor powers one wheel that would probably be an uneven motion under acceleration.
Front wheel drive would be safer I think- hub drive or scrub drive (on the tire) if they still sell that option! Best of luck!
09-14-2009, 07:48 PM
#19 (permalink)
I just assumed it was a live axle.
09-14-2009, 10:38 PM
#20 (permalink)
Ecomod noob
Madison, yes, I am a large guy. But the trike isn't for me, its limit is 250#. And I am losing a bit (why I'm on my own bike). My knee issues are divided between bad genetics, and not being so good to myself in my younger years. Downside to being a bigger guy, people expect me to help them move heavy stuff (or break loose big tight fittings...). Also, being larger, means not fitting in some cars. For instance, I can only fit in a Toyota MR2 with the door open and the roof off.
Rear axle has a standard three pin drive hub on the right side, the left side is just riding on bearings.
Mike, man... I'm not understanding your acronyms. But I won't have any issue fabricating stuff... I'm a Jeep guy!!!
