Old 04-01-2009, 09:19 PM   #41 (permalink)
I think you missed the point, which is that rail cars have very low rolling friction. I sure don't think it's possible to push an empty semi trailer on level ground, though it's much lighter than a railroad car.
Old 04-01-2009, 09:31 PM   #42 (permalink)
Moderate your Moderation.
Herbie - '86 Golf Diesel
90 day: 51.89 mpg (US)
Steve - '92 Festiva
Then why not state the actual point in the post instead of dancing around it with over-verbose descriptions?
Or: You could have just said "The rolling resistance of a rail car is less than that of even an empty semi-trailer."
Joking: That's because the Semi-trailer has a jack stand on it.
Believe me, if I missed the point (I didn't, actually, but easily could have.) several other people reading WILL miss it. (Go ahead, take inference from that, if you must.)
I actually did understand what you were saying though. Arguments and debates aside, it would take a substantial weight differential before metal rolling on metal would surpass rubber rolling on asphaltic concrete for rolling resistance.
Evidence of this fact comes when a simple trailer gets a flat tire, and the sidewalls are soft to begin with, such is the case (normally) with utility trailers (for lawn tractors). The trailer doesn't weigh more than 300 lbs, usually, and has two tires. One goes flat, it's just over 150 lbs on that one tire, *bias caused by yaw condition* yet you have to nearly exhaust yourself to get the trailer moving, whereas with fully inflated tires, you can move the whole 300 lbs and then some without a second breath.
Thinking in those terms, unless a rail car somehow managed to get a "flat" (see: locking up the brakes for some dummy drunk in his car, parked on the rails) it would continue to have less rolling resistance than even an unloaded 3-ton trailer (yeah, 6,000 lbs sounds right...)
Old 04-02-2009, 01:16 AM   #43 (permalink)
"Over-verbose description"? Come on, it was one sentence, and only a single comma. Not even a single semicolon :-)
Over-verbose or not, I think it said what I wanted to say, and would have gotten the point across quite well to most people. Who'd take a dull factual statement over the visceral thought of pushing a railroad car? Not your average creative writing teacher, I bet!
Not if it's the second trailer of a pair, and so is mounted on a dolly :-)
Power Steering delete for fuel economy gain - anyone done it? bennelson EcoModding Central 66 03-28-2012 08:06 AM
Converting power steering to electric power steering Daox EcoModding Central 38 01-16-2012 07:53 AM
Why We Have No Wind or Solar Power SuperTrooper General Efficiency Discussion 220 07-20-2011 10:37 PM
Diesel Power Magazine Disappointment. ConnClark EcoModding Central 16 06-05-2009 10:39 PM
Nuclear Power ... trikkonceptz Fossil Fuel Free 13 06-16-2008 07:51 PM
