Old 01-05-2008, 02:42 AM   #11 (permalink)
Dartmouth 2010
SVOboy's Avatar
Vegan Powa! - '91 CRX DX
90 day: 66.52 mpg (US)
A big old heat sink? Something like a WVO heating system but just for the coolant to wrap around the exhaust?
Old 01-05-2008, 02:47 AM   #12 (permalink)
nut
Coyote X's Avatar
Metro XFi - '93 Metro XFi Convertible
90 day: 62.17 mpg (US)
DR650SE - '07 DR650SE
90 day: 55.26 mpg (US)
Moonbeam - '94 Astro Conversion
90 day: 22.31 mpg (US)
Send a message via ICQ to Coyote X Send a message via AIM to Coyote X Send a message via MSN to Coyote X Send a message via Yahoo to Coyote X Send a message via Skype™ to Coyote X
cut a pop can in half and clamp it to the tail pipe with a small hole about the size of a quarter in it
use a clamp though and not duct tape or it wont be on there for long...
From what my camaro ran like during the brief time I had restrictors duct taped over my exhaust it made it run good at low rpms. The other guy who tested them noticed his car warmed up a lot faster with them on. I think the main benefit would be just the improved warm up time so the hole just needs to be small enough to give a slight back pressure to help build up some heat.
I might test this out if it gets cold and stays that way around here. But tomorrow it is back into the 50's
My Convertible Metro XFI Plug in Hybrid Project build log
Old 01-05-2008, 02:53 AM   #13 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
I was thinking that too.... But once you're warmed up - you're faced with a crap ton of extra heat being added to coolant as it enters the block...
Something like that - just regulated such that it can be turned off...
Challenge me, or correct me, but don't ask me to die quietly.
Old 01-05-2008, 02:56 AM   #14 (permalink)
Dartmouth 2010
SVOboy's Avatar
Well, use a solenoid with a switch, just like a WVO conversion eh? Or even a temp switch that bypasses the exhaust portion at ~170.
Old 01-05-2008, 02:59 AM   #15 (permalink)
MechE
Perhaps I should read up a bit more on the WVO heat exchangers (I've only seen coolant type exchangers - does an exhaust type exist?).....
I'm not trying to be completely negative - just pointing out what I think are obvious problems in thought.... Do you think there'd be a problem with the isolated coolant boiling off (in general, causing pressure issues)?
Old 01-05-2008, 03:01 AM   #16 (permalink)
Dartmouth 2010
SVOboy's Avatar
No no, no exhaust type...I mean the coolant type but I set up the analogy badly...In our case the WVO would be the exhaust and instead of heating it we're stealing heat from it.
It's definately an issue. I think we'd have to worry about how hot the exhaust gets...I'm assuming pre-cat...Where does coolant boil at?
Old 01-05-2008, 03:26 AM   #17 (permalink)
MechE
Depends on concentration of antifreeze, antifreeze type and pressure... But I've seen 50/50 mix @ 15psi brings the boiling point to ~275F (number floating around on the interwebs)... Which AFAIK is below precat temps...
Old 01-05-2008, 03:31 AM   #18 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
Heat exchangers are a PITA IMO, like Coyote X said restrictions are the way to go. Old domestics had a spring/flap on the exhaust for warm up, old skool internal EGR I guess. The flap would stay closed'ish and not all the hot gas would exit the combustion chamber until the manifold warmed up enough/the spring rate dropped enough and the flap popped open.
Edit- What about one of those cable actuated exhaust cutouts?
Old 01-05-2008, 10:16 AM   #19 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
I think a block heater would be cheaper than most of the suggestions thus far.
Old 01-05-2008, 10:33 AM   #20 (permalink)
MechE
It's not an option for anyone that isn't near a plug :/
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 04:39 PM
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 48 11-15-2008 07:08 AM
