Old 01-05-2008, 11:35 AM   #21 (permalink)
Hybrid Student Driver
RH77's Avatar
Teggy - '98 Integra LS
90 day: 33.38 mpg (US)
IMA - '010 Insight EX
90 day: 42.69 mpg (US)
Tessie - '06 TSX Base
90 day: 27.1 mpg (US)
JC Whitney to the Rescue!
Originally Posted by trebuchet03 View Post
It's not an option for anyone that isn't near a plug :/
That's exactly the problem -- I have block heater, but there's no place to plug it in at work, or in long-term parking.
This conjures up memories of the JC Whitney "Turbolator", which is essentially a butterfly valve in an exhaust tip application. Too bad it's expensive.
I don't think anyone ended up testing the device -- it has some hefty claims. We need a lab and funding
Retrospectively, the later-model Nissan Altima 2.5's have a dual-stage muffler that acts in this manner, with altered flow at different RPMs. I hadn't considered it as part of warming-up faster. Hmmmm.
It's supposed to get back up to near 60F this weekend (it was +5F on Wednesday!) -- so testing will have to wait. Don't worry it will get cold again.
RH77
Supporting those devastated by the Joplin Tornado
EF5 / 22-May-2011
_
_
Old 01-05-2008, 12:37 PM   #22 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 57.08 mpg (US)
CM400E - '81 CM400E
Quite a good point. I guess I assumed too much.
Okay the, other ideas for quick warm up from quick/easy to expensive/hard.
1) Not using the heater. Keep the heater on full cold so it doesn't use your hot coolant to heat up the heater core. Problems include freezing your butt off and fogging of windows.
2) Full grill block and underbody tray. Must watch coolant temps very closely and have a way of removing some of the blocks if necessary.
3) Warm air intake. Using already warm air instead of heating up cold air will make the engine warm up faster.
4) Insulated coolant tank (like the 2nd gen Prius has). Tank stores hot/warm coolant and exchanges it with the cold coolant in the engine block upon startup. Not cheap or easy.
Old 01-05-2008, 08:14 PM   #23 (permalink)
101% win
roflwaffle's Avatar
Camryaro - '92 Camry LE V6
90 day: 31.12 mpg (US)
Toy - '82 Pickup
90 day: 24.44 mpg (US)
What about a deep cycle battery and an AC inverter?
Old 01-06-2008, 01:20 PM   #24 (permalink)
RH77's Avatar
That's a good idea, but I recall having performed the calculations a while ago for something like this.
On a quick search, I found that the average deep battery produces 100 Watt-Hours. If the EBH is in the range of 400-500 Watts, then your looking at 12-15 minutes of full power. Inversion may loose some in the translation -- but it takes at least an hour to get some appreciable gains to overcome the weight of the extra battery.
Batt experts can probably chime in here, but I think this is the case. The same goes for solar -- not enough power for the heater.
RH77
EF5 / 22-May-2011
_
_
Old 01-06-2008, 07:29 PM   #25 (permalink)
101% win
roflwaffle's Avatar
Toy - '82 Pickup
Isn't it usually ~100Ah@6V/~50Ah@12V? For example according to the chart on this page, the T-105 will last for 115minutes@75A. Since it's a 6V battery that means it can put out 75A(6V)=450W for a little under two hours. If the current draw is doubled even less power will be extracted, so I don't think it could run a 1kW BH for an hour, but it should be able to run a 400-500W BH for an hour.
Old 01-07-2008, 12:48 AM   #26 (permalink)
RH77's Avatar
Ah, that might be valid then. I looked at 12-volt units instead (don't know if that makes a difference -- the idea would be to include it in the summer months as part of the car's 12-volt system, to power accessories, assist in the regular batt in EOC re-starts, etc.)
Also, would there be some loss in the the DC-to-AC conversion?
Rh77
EF5 / 22-May-2011
_
_
Old 01-07-2008, 01:03 AM   #27 (permalink)
101% win
roflwaffle's Avatar
Toy - '82 Pickup
Definitely, although I'm fairly sure they are small. I have a kill-a-watt and a spare battery I can test those losses w/ if you would like. Also I think having it separate for cold starts and hooking it up to the system in parallel after would be the best bet, just so the BH has no chance of depleting your starting battery if the deep cycle is run down.
Old 01-07-2008, 01:12 AM   #28 (permalink)
Giant Moving Eco-Wall
DifferentPointofView's Avatar
The Jeep! - '95 Grand Cherokee ZJ Laredo
90 day: 23.75 mpg (US)
The Caliber - '07 Caliber R/T
90 day: 30.6 mpg (US)
The 'Scort - '98 Escort LX
Someone said something about more efficient cars heating up slower than non-efficient cars.
This is only the case if the engines are the same cc's, Because my mom's Caliber warms up in a bout a mile, my Jeep takes about 5 miles to warm up. and it's a 4L I6 VS. 2.4L I4
Yea.. I drive a Jeep and I'm on a fuel economy site, but you just wouldn't understand... "It's a Jeep thing!" *Jeep Wave*
Did I Use Too Many Abbreviations? Here's The Abbreviations List
Old 01-07-2008, 08:46 PM   #29 (permalink)
chop suey
Blue - '93 Tempo
ShWing! - '82 gold wing Interstate
F150 - '94 F150 XLT
Sport Coupe - '92 Tempo GL
Moon Unit - '98 Sable LX Wagon
Old domestics had a spring/flap on the exhaust for warm up, old skool internal EGR I guess. The flap would stay closed'ish and not all the hot gas would exit the combustion chamber until the manifold warmed up enough/the spring rate dropped enough and the flap popped open.
Guess again. The thermostatic flaps closed up when cold to route hot exhaust through passages in the intake manifold, to heat the carb. They did not restrict exhaust enough for any EGR action.
Old 01-07-2008, 09:04 PM   #30 (permalink)
MechE
The Wagen - '00 Jetta GLS
90 day: 32.72 mpg (US)
I think that was a reference to thermal efficiency - not fuel efficiency.... A 100% efficient engine will never warm up (all heat input is converted to useful work rather than a portion going to work and the rest waste heat) Too bad such an engine can't exist
Challenge me, or correct me, but don't ask me to die quietly.
Winter cold start & idling warm-up experiment MetroMPG Hypermiling / EcoDriver's Ed 17 12-17-2010 04:39 PM
Cold air VS Warm Air Intakes - what's the difference? deadman1474 EcoModding Central 48 11-15-2008 07:08 AM
