Old 05-03-2010, 05:13 PM   #31 (permalink)
Andrew63's Avatar
Little Green Car - '99 Civic VP
90 day: 34.34 mpg (US)
Originally Posted by diesel_john View Post
Frank: I was wondering when someone was going to pick up on that. Only people (OK, and the wee animals etc.) feel "wind chill". Machines can only get as cold as the ambient temp, regardless of the icy breezes whistling past
i figured you meant that. But its real hard to warm up a little engine driving around in freezing temperatures. Esp . if your only burnin 1gph. Half goes out the exhaust, 1/4 goes to the wheels, 1/4 goes thur the heater to heat the cab. and that leaves nothing to keep the transmission and rad warm.
i have used JD HyGuard in my trans now for a year. (hydraulic oil)
i got a pair of kitchen drawer guides, going to make my variable blocker a sliding door.
You're saying that forced convection heating and/or cooling does not work on inanimate objects. That would be an incorrect statement.
Civic Block Heater Install TomO DIY / How-to 42 04-04-2012 08:24 PM
Mini experiments: 300w vs. 800w block heater warm up time MetroMPG EcoModding Central 40 01-06-2011 01:33 AM
Home-made grille block / bra jodydewey Aerodynamics 5 04-05-2010 01:27 PM
Video: active aero (grille block) via shape memory alloy MetroMPG Aerodynamics 7 01-30-2010 11:21 PM
