03-01-2017, 12:12 PM
#51 (permalink)
something similar
Originally Posted by Hersbird
I was thinking of something similar but bigger and attached to the bed not the cab. So something like this but with a long moveable center piece added.
I thought about the side wings as well as the camper is 8' wide, wider than the truck.
That would make the truck more like a conventional notchback car,or extended cab/shortbed pickup with tonneau.
If you camber the roofline down as you see in some of the contemporary concept pickups,you're going to see a drag coefficient which is closer to that of a passenger car.
When towing,hinging it up from the front and filling in the voids on the sides,like AeroStealth did with his F-150 Aerolid/APEX RV trailer combo would get you NASA-like performance.
03-02-2017, 08:43 AM
#52 (permalink)
Apparently I took this picture in 2012 and never posted it. The manager said he knew it improved the gas mileage but he didn't know how much.
For trailer towing, I think the solution would involve overlapping plates that would unfold like a beetle's wings.
03-02-2017, 10:36 AM
#53 (permalink)
Or like those frilled lizards with the head crest. Maybe I can intimidate any would be predators as well.
Does anyone have any idea of what kind of forces a 6 foot wide, 3 foot long wing would see angled up into the wind at say a 45 degree angle or more at say up to 70 mpH?
I was thinking of making the frame out of conduit and maybe trying foam covered in fiberglass. Like a surfboard with conduit just under the skin all aroundbthe edge. Then hinged at the front with drop down adjustable legs to get the angle if towing, or taper if unloaded
The Following User Says Thank You to Hersbird For This Useful Post:
03-02-2017, 06:47 PM
#54 (permalink)
Non-overlapping plates with webbing for a serrated edge?
03-03-2017, 09:41 AM
#55 (permalink)
I used to post such questions in the forum below, looks like "Mechanical Engineering" not "General Physics" is the subsection you want.
https://www.physicsforums.com/
The answer is "huge", but don't quote me on that.
EDIT:
I went ahead and created a thread, maybe we will get a bite, maybe some deserved ridicule for being dummies, don't know yet.
https://www.physicsforums.com/thread...70-mph.906287/
03-03-2017, 12:36 PM
#56 (permalink)
wing at 45
*no data has been published for a non-towing truck with up-swept wing.
*there hundreds of different airfoil shapes which have been tested,@ zero-lift,to maximum lift angles-of-attack.Abbott and Von Doenhoff's book would be the source for that data.
*a simple inclined surface at a fixed angle on the ground or on a wall has been tested but I don't have that with me.Sighard Hoerners book,Aerodynamic Drag, would have that.
*If you're running without pulling a trailer,the wing should be slanted downwards.Here are some examples of what a rear slope can do
03-03-2017, 12:56 PM
#57 (permalink)
Originally Posted by kach22i
Thanks! Your post is hilarious over there BTW.
03-03-2017, 08:00 PM
#58 (permalink)
Count the fasteners. Look at the size of the washers under them. Look at the thickness of the aluminum. Consider the engineering in the turnbucle/clevises to tune the flight altitude.
This is for downforce. They said they have to take it off to get the car on the trailer and that took 45 minutes; but it's worth doing, apparently.
I'm thinking beach umbrella ribs; maybe ten of then across the top rear, ganged together in parallel. There is your frilled lizard right there. No towed vehicle, retracted — no downforce. Extended with towed vehicle, it only has to maintain the bubble instead of a hurricaine-force onslaught. Fix the struts to the vehicle and move the ends of the ribs and it will extend backward.
03-04-2017, 12:58 PM
#59 (permalink)
some numbers for a 45-degree 'wing'
*Hoerner assigned Cd 1.03 for a 45-degree-angled structure.
*We know that the hypotenuse,C of this right-angled triangle is 3-feet.
*and from the Pythagorean Theorem : A-squared + B-square = C-squared.
*and @ 45-degrees,A = B.
*then,C-squared = 2A-squared.
*and C-squared = 9
*then A-squared = 9/2,or, 4.5.
*and the square root of 4.5 = 2.121-feet.
*so the frontal area is 6-feet by 2.121-feet,or 12.727-sq-ft.
*and CdA = 1.03 X 12.727 = 13.108 sq-ft.
*On say,a 2014 F-150 of Cd 0.402,and 36.0 sq-ft frontal area,we have CdA= 14.472 sq-ft.
*CdA of the truck and wing is 13.108 + 14.472 = 27.58 sq-ft,
*and adding 5% interference drag (as per Hoerner's methodology),we get CdA 28.96 sq-ft.
*The frontal area of the truck and wing is 48.727 sq-ft.
*dividing that into the CdA of the 'rig' gives Cd 0.595 for the pickup driving around with the wing on,but not towing anything.
*This would be like driving six 1st-gen Honda Insights simultaneously.Ouch!
03-04-2017, 01:20 PM
#60 (permalink)
Originally Posted by aerohead
This was online,but no performance claims were made
I found a sister image to that image - I think.
https://www.rv.net/forum/index.cfm/f...print/true.cfm
The Following 3 Users Say Thank You to kach22i For This Useful Post:
