Old 08-22-2010, 07:50 PM   #1 (permalink)
Got soul?
Soulster's Avatar
Soulster - '010 Soul Plus
90 day: 35.36 mpg (US)
100k POS - '01 Neon
How to: Kia Soul front grill block (my first mod :) )
Here is the first mod I've done to my car, and as such it will not look the best, but will give ya' a good idea of what it looks like on a Soul.
Then I taped up paper and penciled in a rough shape.
Transferred onto cardboard... tweaked the curves so it fit.
And transferred to cloroplast.
Then some paint
From 15 feet it's hard to tell its even there
Old 08-22-2010, 08:24 PM   #2 (permalink)
rav
Gas HOG - '08 LIBERTY SPORT
Looks very good!!
Old 08-22-2010, 09:38 PM   #3 (permalink)
Got soul?
Soulster's Avatar
100k POS - '01 Neon
Thanks! It took me about an hour seeing as it was my first time...
Does anyone think I should block more of the lower grill?
Old 08-22-2010, 11:06 PM   #4 (permalink)
Mica Blue - '05 xA RS 2.0
90 day: 48.22 mpg (US)
Josepha - '08 xD
90 day: 30.76 mpg (US)
It's hard to see the lower grill opening. What does the plenum area in front of the radiator look like? Is there a cover over the "chin" area, or is it open?
Old 09-03-2010, 12:31 AM   #5 (permalink)
Got soul?
Soulster's Avatar
100k POS - '01 Neon
No its all open in the "chin area" as well as the three inlet holes near the bottom.
However, the outdoor temps have been hitting 90F and the scangauge is reading 212F before the fan pulls it down to 206F... What temp is too hot?
Old 09-03-2010, 06:52 AM   #6 (permalink)
Daox's Paseo - '97 Paseo
Last 3: 53.99 mpg (US)
Daox's Prius - '04 Prius
90 day: 54.91 mpg (US)
CM400E - '81 CM400E
I'd make a grill block for it. I wouldn't use it just yet, but when winter rolls around you'll be happy you have it.
Old 05-05-2011, 12:24 PM   #7 (permalink)
Toaster Oven Driver
Traction Uncontrolled - '011 Soul base
90 day: 33.26 mpg (US)
How did it affect your FE? Can you quantify it?
Old 05-05-2011, 04:25 PM   #8 (permalink)
Got soul?
Soulster's Avatar
100k POS - '01 Neon
In ABA testing I found a .35mpg increase and over the span of this last winter it shaved the warm up time by about 2 miles. (When cold I'm getting 29-30mpg, warm 33-36)
Old 05-05-2011, 06:24 PM   #9 (permalink)
Toaster Oven Driver
Thanks for the response...I think I'll wait to do a block until fall rolls around. I don't want to have to worry about my drive home when it's 110 in the Delta. But I do like the idea of reducing my warm up time. I'm kind of pondering the mesh screen grill block debate, but haven't reached any solid conclusions on giving it a try.
In general, I'm getting better though, when I drive it, I get 34+, when my fella drives it, he usually can't achieve 32. He's not quite precise enough with the clutch/trans/gears, since he's more used to automatics.
Old 05-06-2011, 04:31 PM   #10 (permalink)
temps
Contact your local Kia service dept. manager and ask what the specs are.
Thirty years ago,some cars were operating with 255degree F operating temps under higher cap pressures.
how to, kia, soul
DIY - Front Grill Block - 1991 Honda CRX SVOboy DIY / How-to 33 06-24-2011 05:16 PM
Grill Block Summary 4536 Aerodynamics 19 07-22-2010 11:55 AM
Advice Please - Upper Grill Block (first aero mod) Arragonis Aerodynamics 3 12-16-2009 07:11 AM
Civic grill block, front undertray, tire deflectors daqcivic Aerodynamics 24 05-13-2009 03:52 AM
Spring mounted Grill Block cfg83 EcoModding Central 32 04-19-2009 06:00 PM
