How long do your cell phone chargers last?
I bought one last night from Best Buy and it is already doing the Not Charging, Charging, Not Charging nonsense. I have been keeping them plugged in as much as possible, unplugging the other end when necessary, and carrying the cord with it, still plugged in. I have not unplugged this cord since purchasing it last night!
One roommate said his iPhone's chargers lasted him years, but I am pretty sure the longest any have lasted in my Android is a month. It is two and a half years old. I have considered replacing the charging port, but often when I fixed my laptop, something tiny and fragile broke. I don't want that happening with my phone! |
I have used wireless chargers, but the "fast charger" barely maintains my battery if I am actually using it, but after a couple of weeks they also started doing the Not Charging, Charging, Not Charging nonsense.
My previous phone used to last about a week on its battery, but gradually it went down to less than a day - awkwardly, in lumps and with exceptions.
Then it started resetting itself for no reason. Also the USB connector did not fit really nice anymore... Long story short; dirt in the connector was shorting the power bearing contacts! One good clean and it lasted a week again. Maybe that helps you too. |
A 2.5 year old phone? I would bet the battery is very near end of life (approaching 1000 cycles). And yes, dirt and corrosion will cause problems on the charging contacts, but you problem sounds like a loose wire or the charger is not powerful enough and the voltage is sagging under load so the phones charge controller shuts down.
The cords last a year or 2.
I have not had a 120v to 5v USB power supply go bad. If the phone turns off for no reason you probably have a bad battery. |
Dunno. Use my PC to charge most things.
Oh, wait...there's the tablets. They have AC USB chargers. They've been going for years. Occasionally have to replace a dead USB cable though. |
Every one of my chargers outlasted their respective phones, and I never had problems with charging. I follow simple rules:
- never leave charger in AC outlet ( ?wall socket?) when not in use - do not use (phone, walk, surf etc) while charging - Plug and unplug softly, keep socket clean - Full charge, full discharge - do not bend cables |
Mine last forever. The only thing I've noticed since I got an iPad is that the phone chargers won't charge it because it needs more oomph (that's tech jargon for amperage).
My life is un-troubled by such things, but in general —with consumer electronics— things tend to fail out of the box or at the end of life after a long stretch of reliability.
Your part hadn't achieved burn-in. If it wasn't this way you wouldn't have received a warranty with it. |
They always outlast the phone. Never had to replace an OEM one.
